10-24-2018, 02:40 PM
Mejnour Mejnour is offline
Here is screenshot of my working ATI 9600 Pro Card DD version.
Only complain spyder is not able to load color profile, I tried to load it manually in the card set-up without succes.
I tried to find a update for the Radeon 9600 Pro family without succes. Then I updated with the more recent AIW 9600 drivers and bingo the color profile load by itself but then I lose capacity to capture in Virtualdub. The ATI Rage Theater Video Capture disapear to be replace by a not working ATI T200 AVstream anolog capture.
Any Idea how to solve this annoyance?
10-24-2018, 09:14 PM
Maybe you haven't noticed, but none of your screen shots will display.
I never heard of anyone trying to load a monitor calibration profile using a graphic card's display driver. I thought .icm's were loaded either by your Spyder software at startup or configured in the Advanced and Color Management properties of your monitor display dialogs (Desktop "Properties"). Or perhaps we don't read you correctly, since your screenshots aren't mounted properly and don't display.
10-25-2018, 01:55 AM
Here is attached images
Under 6.14.10.6463
Able to capture
Color profile block
Under 8.241.0.0
Losing Rage Theater capture option in virtualdub
Color profile is load
10-25-2018, 02:01 AM
I may mixed thing for sure and surely I don't indetstand all the details going on ATI installation drivers...but I tried many things before trying to update card driver...
This is why I posted image so maybe some of the guru on this forum see something that is really not obvious for me
Thanks for the image notice
10-25-2018, 03:03 AM
In "original DD.jpg":
* Use the tab at the top of the dialog: "Gestion des couleurs".
* .icm profiles are located in Windows\system32\spool\drivers\color.
10-25-2018, 04:02 AM
Thanks salyn
Already tried this, when I load any kind of profile available, nothing happens.
I thinks I will wipe all ATI stuff and just tried a clean install again.
10-25-2018, 04:06 AM
[EDIT]
I don't have the PRO version just ATI 9600, I was assuming that it was the PRO version when I read the LABEL on the associated with the 6.14.10.6462 drivers version, So I guess that my only problem now is to get back the capture ability in virtualdub.
Sorry for the wrong information
ATI All In Wonder 9600 best drivers? DirectX? VideoTechMan Capture, Record, Transfer 6 10-18-2018 12:19 PM
Which color profile I should choose...? cmoff General Discussion 3 10-06-2014 08:14 PM
Which color profile to use, when batch processing photos for the web? Sossity Photo Processing, Scanning & Printing 1 11-07-2012 05:42 AM
Spyder 3 vs Eye-One Display 2 for monitor calibration manthing Photo Processing, Scanning & Printing 1 02-07-2012 05:02 AM
ATI AIW 9600 Drivers jrnyhead Capture, Record, Transfer 2 03-30-2008 07:31 PM
