06-30-2019, 09:48 AM
I have been having FITS trying to capture a tape where I get no dropped frames but in 90 minutes I get 300 inserted frames.
Needless to say the A/V sync is way off.
Setup is/was S7800U>ES-15>TBC-1000>Hauppage WinTV50>Windows 10.
Tried both with and without the ES-10.
Tried it in my Sharp VC-S101.
Not until I switched my dongle to the Diamond THEN only 2 inserted frames (so far).
Just sharing the experience.
06-30-2019, 10:43 AM
Have you tried setting the process priority to high or realtime? I've found it can often be helpful.
If you're getting them behind the combination of es10 and tbc-1000 it would suggest it's something on the computer end causing problems.
Note that it's possible to tell virtualdub not to insert frames in the options if it's a big problem, but getting them tends to suggest either the source is unstable or something is giving the computer trouble.
06-30-2019, 11:09 AM
It is an old tape (aren't they all), and using the Diamond I got 3 inserted frames in 53 minutes, much better.
As for my computer, I shut off AVG and unplugged the internet before, but only changing the dongle made a difference.
frames, insert
Dropped/inserted frames? koberulz Capture, Record, Transfer 4 07-27-2018 03:28 AM
Inserted frames in VirtualDub after new PC build? thestarswitcher Capture, Record, Transfer 8 07-12-2018 08:03 PM
Inserted frames in VirtualDub? (Argh!) thestarswitcher Capture, Record, Transfer 5 07-01-2018 02:08 AM
Trying to Understand Inserted Frames premiumcapture Capture, Record, Transfer 10 04-17-2017 06:59 PM
VirtualDub - frames inserted? lookouts Capture, Record, Transfer 3 10-15-2006 09:28 AM
