-   -   Panasonic AG-1980P shows no video? (https://www.digitalfaq.com/forum/vcr-repair/10910-panasonic-ag-1980p.html)
darko886 08-18-2020 03:56 PM
Good afternoon,
I have an AG-1980P that accepts a tape, plays it, but only outputs audio. The entire time the screen remains black. I've tried both the s-video and the BNC have the same issue. Nothing shows up on the screen at all at any point in time. Any ideas?
lordsmurf 08-19-2020 02:17 AM
Odd. Usually disable problem is garbled, not absent.
Did you confirm this on a TV, not just a capture card?
Or did you confirm capture card and setup is fine, using another VCR?
darko886 08-19-2020 06:19 AM
Using a TV and multiple tapes. Definitely odd
dpalomaki 08-19-2020 08:20 AM
Did you try the antenna (CH3 RF) output to a TV?
If you have an old RF TV signal source (e.g., another working VCR) so you can feed an RF signal to the tuner section, do you get any output?
