12-01-2020, 05:16 AM
geordie10 geordie10 is offline
Hi everyone
Very excited to pickup this machine given the great reviews. However, Ive set it up and encountering the following issue.
Through S-Video out, there is no video signal. I'll try and describe the problem with dot points.
a. Cassette inserts and plays fine. All rewind, FF and play functions occur
b. No error codes
c. There is a flicker on the screen when the system is turned on then goes to blue screen.
d. When video plays, screen goes black. Nothing more. Back to blue when stops.
e. Menu and settings do not appear when pressed. No signs of life, only a black screen.
f. Audio plays fine through the headphone out port on the front.
g. Same issue occurs through both s-video ports.
h. Dont have plugs to test composite and component card not installed.
What is going on here?
Can anyone recommend a repairer in Sydney, Australia?
Thanks for any replies.
12-31-2020, 10:17 AM
I don't understand the appeal of these old decks. More than not, you run into faults. You'd get far better results using the prosumer decks from JVC.
That Sony was mostly an editor deck, wasn't it? (Fairly certain the answer is "yes".)
Random: Found this interesting site while Googling to model: https://amigavideo.net/rec/
Service Manual for Sony SVP-5600P, SVO-5800P VCR [DOWNLOAD] juhok Video Hardware Repair 8 10-27-2020 01:26 PM
Audio signal as video input? renzooh Capture, Record, Transfer 5 08-27-2019 02:48 PM
All of a sudden, I get no video signal? jobeis Capture, Record, Transfer 2 01-09-2017 02:11 PM
Do I lose PQ advantage switching signal from s-video to RCA in signal path ? Mejnour Project Planning, Workflows 4 02-01-2012 05:12 AM
Is it possible to capture component video signal Mejnour Capture, Record, Transfer 5 01-24-2012 07:27 PM
