08-22-2021, 10:09 PM
mikenew02 mikenew02 is offline
When the tape is loaded (which sometimes works and sometimes gets stuck halfway through and auto-ejects) the player does nothing. Pressing the play button does nothing. The screen sits at Auto.
Hitting the power button gets the tape to play for a few seconds, as the video shows, but then it dies and goes back to Auto.
The stop/eject button works and ejects the tape properly (sometimes).
It looks and sounds like some gears are stuck, but I cannot identify which ones or how to fix it.
The noise is the motor continuing to spin even though nothing is moving.
08-22-2021, 10:42 PM
Check your tapes, they sound sticky to the drum.
08-22-2021, 10:49 PM
I've tried three different tapes, they all behave the same way.
08-23-2021, 12:44 AM
The drum is not spinning free for sure and that requires a qualified technician to take it a part to repair, It is not something that can be fixed over a forum posts unfortunately.
08-23-2021, 05:40 PM
Dougmc Dougmc is offline
As latreche mention , if something sticky
Is on the head it will create an issue no matter what tape
You put in.
Heads need cleaned then proper way. Any belts slipping on pulleys?
09-01-2021, 11:04 AM
I fixed it. It was the mode switch.
JVC HM-DH40000U is shutting down? LinParkFL Video Hardware Repair 22 01-13-2026 05:37 PM
JVC HR-S7600AM keeps shutting down after 3 seconds? Blackout Video Hardware Repair 128 07-12-2025 03:59 AM
VCR keeps shutting off when tape inserted? bryanac625 Video Hardware Repair 7 06-06-2019 09:27 AM
S-VHS JVC HR-S3500U for sale [SOLD] latreche34 Marketplace 2 04-16-2019 07:09 PM
Seeking JVC HR-S3500U head cleaning advice elpablo1 Video Hardware Repair 3 06-08-2016 11:02 PM
