-   -   Tray Won't Open (https://www.digitalfaq.com/forum/vcr-repair/12263-tray-open.html)
gregavi 10-30-2021 02:00 PM
Tray Won't Open
Hi. New to this forum. I have a Pioneer Elite and a Denon Blu Ray Player that are having a very similay issue. The tray will not open unless there is a disc in the tray. Kinda strange behavior. I have taken the cover off of each and find that if I push down a little on the top of the tray while it is trying to open, they both open. I then put a disc in, and they open and close with no issues. Any ideas as to what causes this and what a fix might be? I'm thinking it's the gears that open the tray that need greasing but not sure.
Thanks in advance.
dpalomaki 10-31-2021 10:17 AM
Does the empty tray start to move and stop after a little bit of motion, or does it not even try to start o move? Perhaps a motor tries to start and stalls.
When you push down on the tray is there any noticeable downward movement of the tray (not in the opening direction)?
Is this a changer, or a single disc player?
You could try carefully clean then lube the gears and the track/slides, and look for any binding points or burrs that might impede opening.
If it fails to even try to start to open look for a sensor. Also, check all ribbon cable connections and perhaps clean the contacts. I've seen strange behavior on DVD players (and other gear such as even dishwashers :huh1:) that was traced to corroded ribbon cable contacts.
gregavi 10-31-2021 06:02 PM
It definitely tries to open but just doesn't quite. I lubed the gears the best I could (they're hard to access) and it seems to be working now. We'll see if it continues to work.
