packsnap85 |
04-24-2022 11:28 AM |
JVC MV55 service manual?
Would anyone be able to point me to a service manual for a JVC mv55 dvd recorder/vcr combo? I need to replace the pinch roller (which seems like it should be a whole lot easier than it appears to be unless there’s some trick I am missing), and I want to make sure I disassemble all that I need to before I start pulling stuff apart with too much force. I am assuming there is a clip or screw on the bottom side of the metal plate where the roller lever mechanism is attached. I got to the point where I had all of the screws out of the bottom plate that seem to connect it to the chassis below, but there still seemed to be some attachment around the drum area that prevents me from lifting the bottom plate.
