Phillips DVDR-3510V eject VHS after 8 seconds?
1 Attachment(s)
Hello. I have bought this Combo DVD - VHS for 12$
DVD works fine , Video Outputs works. I have found this model interesting because have SVideo output support. The problem here is that after 8 Seconds of VHS playing, the VCR eject the tape. That 8 seconds that can play, it shows image and audio. Do you know what could it be? Note: If Im playing a DVD, and I insert the VHS, it stays in stand by mode, with all the tape place in the head drum (but no playing because player is in DVD mode) . In that case, the VCR don't eject the tape. If i go into VCR mode, it starts play VHS, and 8 seconds after, it eject tape. I attach one video showing all. thanks for your help. |
Obviously a mechanism problem, Needs to be taken a part, cleaned, lubed, check the mode switch and clean it, align everything and put it back together and go from there.
