Mitsubishi VCR: What's this error, why immediate eject?
I'm trying to fix up a Mitsubishi HS-U560 VCR. I've got the mechanism cleaned, aligned. I can manually turn the gears and get it to go through the load/unload sequence just fine.
At this point, I see a showstopper problem, and what looks like it might be an error code on the display. Have found no service manual nor online info that addresses this. Ideas most welcome! Issue: if I load a cassette, it pulls in, door opens, drops into position, but does not pull out the tape... and immediately reverses, ejects, and turns off. Issue(?): When turned on, the display shows "3". No idea what this means.. |
I detest Mitsubishi decks, always crappy.
Mechanical issues like that can be related to gears, belts (rubbers, bands). Sometimes motor is shot, also a weak fail point on JVCs. Without service manual, no clue. Another problem is that Mitsu decks had low production, not popular, info sparse at times. You may be SOL for official repair docs. But most brands had semi-universal codes, another Mitsu model manual may always show what '3' means. Sometimes stuff isn't covered in any manuals. I had this issue with a Dell laptop recently, light combo not covered. I read other manuals, guessed issues correctly, unit now works well. Welcome to my world. Few others here too, so welcome to our world! Having fun yet? :laugh: This is why DIY repair, DIY refurb, is a PITA. You spend all your time making gear work, not using it. Your videos will never get transferred that way. Just something to remember. <<< This is addressed to others reading along, not our dedicated OP here ... probably? |
@lordsmurf, you've obviously been around the block a few times LOL
Yep. I actually began as our family A-to-D conversion "expert" a decade ago. Biggest mistake: I gave myself permission to take as much time as needed to get it done. What I didn't consider (but really Ought To Have Known):
