-   -   Different serial numbers for JVC capstan motors? (https://www.digitalfaq.com/forum/vcr-repair/13631-different-serial-numbers.html)
AMG-Power 07-19-2023 03:30 AM
I have a JVC HR-S7500EH from 1998, this is a NICAM A2 player for Europe.
It has playback issues, it loses colour from time to time watching movies, sometimes I only see green and red colour on screen rest of the colour is like black and white!
If i fast rewind the same scene my VCR plays the same scene fine without issues.
This problem happens random.
Perhaps I have a play in the scart socket, but I don't know?
Been using a very heavy cast ingot scart since I bought my player and these scarts could cause play in the socket and the solderings to crack on scart PCB.
I will take my player to a shop for them to check it out and re-solder the connections.
Been looking to replace the factory fitted capstan motor QAR0032-003 since my player is from 1998 with many hours of use.
When JVC release new parts they supersede old parts numbers.
Later edition capstan motors had parts number QAR0032-005 and on.
On a website I found a capstan motor with parts number QAR0087-005 which seems to fit the French version of JVC HR-S7500 with end suffix MS.
JVC HR-S7500MS is also a European super-vhs player with PAL/SECAM playback.
From 1999, the newer HR-S7600EU - gold chassie and HR-S7611EU - black chassie had this newer QAR0087-005 capstan motor fitted.
Is it possible that the newer series of capstan motor QAR0087-005 also replaced the older capstan motor QAR0032-003 which was fitted to HR-S7500EH and HR-S9500EH players ???
What happens with the VCR if you put the wrong capstan motor in it besides it won't work properly?
I have bought a replacement capstan motor QAR0087-005
dpalomaki 07-19-2023 09:02 AM
Worst case is burn out the motor, or the driver circuit on the board supplying the motor due to excessive voltage or current. Also, it might not be a good physical fit; e.g., different size or connectors. No way to predict without careful study of the schematics of the VCRs, both the old and the intended for the part. Or finding someone who has already tried it.
Typically substitute parts will be listed if the original is no longer available. And the -003, etc, suffix often indicates a minor manufacturing change in a otherwise equivalent part.
AMG-Power 07-19-2023 10:38 AM
Shop where I bought the capstan motor, they first listed capstan motor part number as QAR0032-003/5 then told me I would get an updated capstan motor QAR0087-005 because the other one was out of stock.
Probably means the successor QAR0087 capstan motor which replaced the older QAR0032 capstan motor they both have same specifications but the newer capstan has some improvements over the predecessor ????
Am I correct?
dpalomaki 07-21-2023 07:06 AM
Am I correct?
I have no idea, and a quick search of the internet does not indicate it is a viable substitute. If you find out, please share the information.
AMG-Power 07-26-2023 11:33 AM
Package with capstan motor arrived but is stuck at customs, will let you know the outcome when i get it back from repair
AMG-Power 08-26-2023 02:04 PM
Heard from my repair guy.
He told me the new capstan motor QAR0087-005 did not fit JVC SuperVHS players using factory fitted QAR0032-003/5, these are not compatible.
The new capstan I bought fits one of my later players so it will not be a total waste of cash.
I can use it as a spare for future replacement
