-   -   Panasonic AG-W1 distorted video? (https://www.digitalfaq.com/forum/vcr-repair/14162-panasonic-ag-w1.html)
digivcr 02-29-2024 02:16 PM
1 Attachment(s)
Likely some repair is needed. Anyone have any idea about a possible fix ?
aramkolt 02-29-2024 05:39 PM
No way to really tell from that, but since half of the image is kind of missing at any given time, would imagine a couple of the video heads are dirty or are just broken.*Could also be cracked solder where the heads are soldered onto a PCB if it uses that design. Could also be that tracking is super poorly aligned.
themaster1 03-01-2024 04:13 AM
Do you get full pictures in fast forward/Pause modes ?
digivcr 03-01-2024 10:23 AM
No. The distorted video will ripple across the whole screen as it play along. Pause or FF won't show the video , I get "No signal" on the app.
themaster1 03-02-2024 03:13 AM
possible solution (but yeah really clean the heads first):
https://www.youtube.com/watch?v=NRRx...ljdHVyZQ%3D%3D
and/or also possibly (drum servos / capstan servos):
https://www.youtube.com/watch?v=FuP4hTfZ36s
digivcr 04-29-2024 10:11 AM
The cleanup of heads and captions didn't help unfortunately. Maybe some electronic component is bad i guess
latreche34 04-29-2024 11:07 AM
These standard converter VCRs are useless for capturing anyway, In my opinion it is not worth spending time and money trying to fix it.
