Datavideo TBC-3000 motherboard recap!
8 Attachment(s)
Hello forum!
Today I recapped this 3 or 4 Generation Datavideo TBC-3000 with Wurth Elektronik capacitors. After measuring all the capacitors, I realized that 70% do not have the corresponding value, so I decided to replace them with better quality ones. It's a very delicate job, but if done correctly, you can extend the the useful life of this wonderful device. If anyone needs maintenance on his TBC, send me a direct message. This is how it turned out: Attachment 17785 Attachment 17786 Attachment 17787 Attachment 17788 Attachment 17789 Attachment 17790 Attachment 17791 Attachment 17792 |
Some of us have this problem:
https://www.digitalFAQ.com/forum/vcr...0-causing.html What causes that? I realize you probably do not know either. But if caps, then why/how? I want to see if Master Tape is willing to sent his to you, as he's just over in Scotland, much closer. |
So I guess the question here is if there were any problems before you recapped it or not? Seems quite a few here have an issue where there's a 1 second blip of horizontal lines per capture. Usually capacitor issues I'd think would create a more consistent problem once up to to operating temperature.
I found on my TBC-1000 that 80%+ of the caps were out of spec (though none physically looked bad). I had something that I'd describe as rainbow static in the vertical blanking area (this is above the normally captured picture, so almost no one really looks for issues there as most displays don't display it without full 525 lines or H/V delay. I haven't tested mine long enough after the recap to verify that it actually went away, or perhaps that's a normal thing with the TBC-1000. I've used Wurth capacitors before, but they always seem to be suspiciously overspeced - like "on paper" they almost always outperform well known brands like nichicon, rubycon, chemicon, and panasonic, for caps of the same physical size which I find to be highly unlikely so I generally avoid them in favor of those others. Kind of reminds me of Chinese lithium batteries that have outrageous capacities listed on them that aren't remotely correct and are gross overestimations. Really all of the capacitor specs are manufacturer reported and most do not require a regulating agency to verify accuracy of claims to my knowledge. I'm sure any new cap is a big improvement over the originals though - even cheap Chinese ones. What do you use for your heatsink paste and do you ever worry about over-applying or not being able to get the heatsinks off later? |
If he has no problem sending it to me, I would have no problem doing the repair, so we can know if the failure is due to bad capacitors. |
These heatsinks that I bought are from a Raspberry Pi 4 pack that I found on Aliexpress, they work very well and do their job. Between the chip and the heatsink is a tape that transfers heat, isn't thermal paste. |
Looks great! Might do the same on my 6000
