-   -   Panasonic F70 squeaking noise? (https://www.digitalfaq.com/forum/vcr-repair/14426-panasonic-f70-squeaking.html)
Thermaltake 06-16-2024 03:03 AM
Hi, I have few F70 on repair and every single one of them have that squeaky noise when tape is inserted, is that some kind of serial problem ? I lubricate everything and greased so I have no idea what can that noise be. I assume it's normal ?
starting in 0:36 here (that noise)
https://www.youtube.com/watch?v=EIc3NC6RG7I&t=157s
timtape 06-16-2024 08:35 AM
A common fault in a machine tends eventually to affect every machine of that type.
The sound seems only to appear when loading so I'd carefully check the cassette load system starting with the load motor.
Thermaltake 06-16-2024 11:40 AM
Can't find where the loading motor is in manual...
maybe motor needs some oil it dried up or something, but I can't manage to find it in manual to inspect it.
themaster1 06-16-2024 01:44 PM
I don't hear noise
Thermaltake 06-16-2024 02:00 PM
Originally Posted by themaster1 (Post 97345)
I don't hear noise
What do you mean ? On that youtube video or ?
Hushpower 06-16-2024 07:52 PM
I don't hear noise
My hearing isn't the best but it is as plain as day at 36 seconds, squeaking as the tape goes in.
timtape 06-16-2024 09:12 PM
I don't hear noise
It sounds like a small bird chirping!
enois 06-17-2024 06:20 AM
That kind of noise is not uncommon on G-deck mechanism. Personally I' we never warned too much about, but for sure a perfect working deck should not do that.
In this deck there is not dedicated loading motor, motor capstan perform loading. The standard version of G-deck has only two motors.
Can you check the braking felt under the motor capstan, try to temporary remove it and listen if noise persist.
Thermaltake 06-17-2024 02:46 PM
I'll try in few days when I get some spare time to deal with that.
