-   -   JVC S9911U belt diagrams? (https://www.digitalfaq.com/forum/vcr-repair/14445-jvc-s9911u-belt.html)
peterm 06-22-2024 10:32 AM
Greetings - having a bit of issue finding responsive repair facility so might do a refresh myself on this. Google isn't helping me a lot here.
Is there a reputable and responsive repair facility out there now?
Are there any diagrams specifically on wear items? (SM is not explicit)
Feedback appreciated!
aramkolt 06-23-2024 07:50 PM
Belt diagrams? Do you mean more like mechanism timing? Really the only belt on that I think is the capstan belt and the loading motor belt which are pretty straightforward.
peterm 06-24-2024 07:35 AM
Thanks, and yes probably mechanism timing. Seems noise occurs every 5-7 seconds no matter the tape. I was initially thinking replacing wearables but perhaps I'm not on the right track.
themaster1 06-24-2024 07:50 AM
Intermittent noise on the picture is not caused by a wrong gears timing or belt if you ask me. More like (from simple to worst) : bad grounding (heads drum, chassis), leaking caps on the power supply or somewhere else. Last but not least failing heads. I don't know everything on vcr's but i know that much
peterm 06-24-2024 08:23 AM
Thank you for this. Perhaps just a good cleaning to start with / check grounds.
