-   -   Sony SL-HF500 weird guide post issue? (https://www.digitalfaq.com/forum/vcr-repair/15280-sony-sl-hf500.html)
jham55 08-02-2025 08:59 PM
Hey there.. this deck plays the tape fine but I cannot clear up the video. It gets way better when I press down the back guide post. The video shows it. If I take tension off it comes back up and the picture gets weird again. Not sure how to get it more aligned. Any thoughts?
timtape 08-03-2025 04:40 AM
No video appears. Possibly one of the guide posts is not fully seating in the slot at the back. Compare it with the other guide.
themaster1 08-03-2025 03:51 PM
Got a deck that has the same problem. What you really need are new loading arm gears (arms + guides) .
On mine the P2 guide just slips/ bend toward the drum quickly and then the top picture is messed up, can happen on the other guide aswell i guess.
You can try using crazy blue on the treads, i doubt it'll work
aramkolt 08-03-2025 04:05 PM
Could be the heads are worn also and the added tension gets the tapes closer to the heads, but yeah, a video would be helpful.
