-   -   What is wrong with JVC HR-7700EU VCR? (https://www.digitalfaq.com/forum/vcr-repair/15316-wrong-jvc-7700eu.html)
Rolle68 10-02-2025 07:10 AM
Originally Posted by radiokom (Post 104848)
You can't get the result with the "like/dislike" method. First you need a properly calibrated VCR. It means you got your reference VCR from well known technician or shop. I have test tapes and experience with Panasonic but, until now, no experience with JVC. I bought a 7722 from vcrshop and then two mint condition 7711 (exactly the same, only black, 7722 is silver) in local sales in small towns in Germany. All 3 work identically, and the picture and sound is identical from both the test tapes and the other VHS/SVHS cassettes. It is possible to tell if your VCR is working properly if you have a calibrated the same model reference VCR to compare it to. Otherwise it is a waste of time. PS recap should be done of course.
This gave me something to think about... I don't have a test tape (which will probably be challenging to obtain) and an oscilloscope, so I need to find out if there is a place nearby that can calibrate JVCs (if there even is one). However, I have to emphasize that I am satisfied with the image quality of the first DVS2 and the 7700. What remains unclear to me is when the vcr processes the image too much:question:
radiokom 10-02-2025 07:36 AM
Test cassettes and other calibration equipment will not give you result you need if you are not familiar with particular VCR model. Each has it's own signature. For example - Panasonic NV-FS200 has excellent G2 mechanism and good TBC, picture is closest to JVC from all Panasonic. NV-HS1000 is good, with K mechanism, but is a bit sharper. NV-HS950 is very sharp, but it does not mean it is bad - there are SVHS tapes what are reproduced excellent. So they all are different. You can buy a reference VCR from vcrshop, calibrate your similar VCRs and then sell it for the same price. I believe I will sell 7722 soon, because I do not need it any more, I have 2 exactly the same 7711. I recapped 7722 PS, because vcrshop do not recap them. And bought remote separately because it came without it.
latreche34 10-02-2025 03:54 PM
It's simple, put the tape with noise in the VCR, hit pause, if the noise freezes, it's recorded on tape, if it keeps moving, it's a faulty VCR.
