09-04-2025, 04:36 AM
AlexEk9876 AlexEk9876 is offline
The Jog Dial (JD) and Shuttle Dial (SD) switches on the machine body do not work! On the remote control, these switches JD, SD work normally. I disassembled the VCR and checked the switch JD, SD in detail - it is good. I checked the passage of the signal to the IC750 pins from the switch - there are signals and they come to the IC750 pins, but there is no reaction. All other functions work normally. I ask for your help, what else should I check? Maybe there are some protective modes that disable the switches JD, SD on the VCR body? for example, child protection is enabled...
09-04-2025, 10:53 AM
Have you checked the voltage coming through, vcr powered on ? probably too low voltage is my guess.
09-04-2025, 01:03 PM
Yes, I checked the power supply, and it's working well.
09-05-2025, 01:25 AM
A short somewhere then...
JVC SR VS20U VCR having trouble Jpass992 Video Hardware Repair 15 08-09-2013 04:06 PM
Pioneer PD-91 CD Player (1987/1990), how to dial in for optimal CD-R playback Tasuke Videography: Cameras, TVs and Players 3 10-31-2011 12:42 PM
Trouble with TBC...HELP! Tom_n_Jonna Restore, Filter, Improve Quality 3 01-21-2006 12:39 AM
Having some trouble... Daniel Capture, Record, Transfer 9 06-06-2005 10:25 AM
