03-08-2026, 07:47 AM
promoter_2000 promoter_2000 is offline
Hello everyone. My Panasonic NV FS90 VCR (PAL version) is having a problem whose cause I can't pinpoint. The other day, after twenty minutes of playback, the TV picture began to be affected by whitish horizontal stripes, varying in thickness, moving vertically. After a few more minutes, the horizontal image began to distort until it became intermittent and then disappeared completely, leaving a black screen. During this entire problem, the audio remained perfectly audible. Now the VCR no longer outputs any image (a black screen), while the audio from cassettes is perfectly audible. I've owned this machine since 1993, and after considerable effort, I managed to restore full functionality two years ago, managing to resolve, thanks in part to this forum, all the endemic defects that plague this Panasonic series. Basically, after replacing the entire head drum with an original Pana model, I replaced the capacitors on the SUB LUMINANCE/CHROMINANCE C.B.A. boards, the 1H DELAY CCD PACK C.B.A., the infamous C3311 on the LUMINANCE & CHROMINANCE PACK C.B.A. board, the four cursed SMDs on the VEFH05BT board that were blinding the S-VHS cassettes, and all the electrolytic capacitors inside the power supply. After all this work, the VTR has always worked fine for these two years, until this new defect whose origin I can't identify (I had basically already changed everything that usually breaks this recorder). At present, after checking the situation, I have found that my recorder does not play any video (black screen) from VHS/S-VHS cassettes through the SCART/RCA/Y-C/RF antenna outputs (leaving only the audio) while it continues to regularly record the audio-video signals from the line inputs (obviously playing those recordings on other VTRs). Even in simple transit (i.e. without recording tape) the incoming video signals do not pass to the output anywhere (the screen remains black). Only through the antenna connection (from the RF output) does the "test signal" of the two vertical white lines appear on the monitor (activated by the appropriate button on the back). Finally, when connecting the CVBS output to a Sony SB V3000 matrix, the orange LED that indicates the arrival of a composite signal remains off, while connecting the S-VIDEO output turns on the green LED (indicating that the matrix is ​​receiving a video stream), but in both cases the screen remains black. I checked the solder joints on the main board, especially the board containing the RCA/SCART connections on the back, but I found no cracks. Now, having already replaced everything I knew to be causing the problem, I can't figure out what the hell is preventing the video signal from coming out from any type of connection. Could someone please give me some guidance on which board might be causing the problem and how to fix it? Thanks in advance.
03-08-2026, 07:48 PM
radiokom radiokom is offline
Looks like heavily clogged heads. Did you cleaned them with paper+IPA? In 90s I had the same problem with one German porn tape. Heads clogged about 30 seconds after cleaning, but sound was still perfect
03-09-2026, 01:10 AM
Unfortunately, I've already cleaned them twice with isopropyl alcohol and paper without success: the paper strips, after cleaning, were still clean (with no signs of dirt). I've always used only self-recorded cassettes on this VTR, never rented ones or ones purchased at a newsstand. I replaced the head drum two years ago, taking it from a used machine. I checked the upper drum with a magnifying glass, and the head gaps still seem fine and easily felt (during cleaning). The fact that the machine works while recording (on other VTRs, the recordings are perfectly visible) leads me to believe the audio and video heads are not damaged. I've only noticed a slight difficulty with autotracking, which I believe is caused by the drum not being perfectly aligned, as it was done "visually" without the aid of an oscilloscope (which I don't have). This was easily corrected by the remote controls.
Panasonic NV-FS90 power supply replacing? promoter_2000 Video Hardware Repair 3 07-14-2022 07:05 AM
Panasonic NV-HS no video or audio VHScollector19 Video Hardware Repair 10 08-26-2021 03:42 PM
FS: New upper drum VEH0467 for Panasonic FS90/FS200/V8000 [ENDED] juhok Marketplace 1 08-12-2017 04:49 PM
Panasonic NV-FS90 ejects the tape after insert thaitobbe Video Hardware Repair 1 09-30-2013 12:39 PM
Panasonic AG-1980 linear audio, s-video? DeeSeven Capture, Record, Transfer 4 09-26-2013 11:48 PM
