01-11-2013, 03:40 PM
bhs00 bhs00 is offline
I purchased a panasonic ag 1980 from ebay and it was delivered earlier this week. I have it connected to an AIW 900 USB stick through s-video. I tried a test capture last night. The color was extremely weak, almost black and white. Is this a known problem with the VCR or tuner card? It was a very short clip that I tried for a test. I first noticed it when I tried an old home recorded tape. But I thought it may be the tape being worn out so I tried a commercial vhs and it did the same thing. Everything was nice and sharp looking, but the color was horrible.
01-11-2013, 04:40 PM
ag-1980's are great VCR's - one of the best.
however they are notorious for bad caps and other problems.
almost any used AG-1980 you buy should be checked out and serviced by a pro.
these where not consumer decks - they where sold to schools and videographers and most have been very heavily used.
your problem sound like some bad caps.
send it out to Southern Advantage - they will go right through it for around $125
once it is 100% you will be very happy with it.
01-11-2013, 04:56 PM
did that include shipping or not? I saw in another thread that you had these same problems. Did they check everything else when you sent it in as well?
01-11-2013, 05:01 PM
that doesn't include shipping.
they will completely service the deck
send them an email for more info
AG-1980 B&W / color switch weird issue volksjager Capture, Record, Transfer 2 02-18-2012 03:13 PM
Problem with Panasonic AG-1980 VCR Superstar Capture, Record, Transfer 2 10-20-2011 01:53 AM
Finally bought AG-1980 Panasonic S-VHS VCR? NJRoadfan Restore, Filter, Improve Quality 13 06-10-2011 09:00 PM
Using the Panasonic 1980 sharpen cyber-junkie Capture, Record, Transfer 13 03-25-2010 06:37 PM
Panasonic AG-1980 as good as JVC S-VHS VCR ? ramrod Restore, Filter, Improve Quality 1 11-13-2009 07:33 PM
