Setup menus on Panasonic Pro AG-DS545P S-VHS?
Preface:
I am working on an archival project with some borrowed and some ebay-ed player decks. The sources were created on similar Panasonic and Sony S-VHS decks over a period of 18 years beginning around 1990. I believe that the player decks that I have were used as feeders for simple editing suites - like for delivery to cable access. Two of the Panasonic machines have scrambled, rolling, greyed and very weak video output. The tape transports and audio (including HiFi) work correctly. The Panasonics have physical switches on the front of the machines and an extensive "Setup-Menu" that is viewable via the backpanel Video Monitor jack (BNC that I am using with an RCA adapter). You flip through pages of the Setup menu with a combination of the Jog Wheel and the front panel buttons. I don't have: - A scope or a typical old school monitor. - a source for reference video sync - happy to buy that if it would help - any certainty that my old gear is working correctly. - an actual manual for the Panasonic decks - I am using pdfs of other Panasonic decks So, I am troubleshooting my way through this. It occurs to me that the Panasonic players may have been configured to suit the production scheme that they were pulled from. I don't have a deep understanding of the menu choices or why they might have been tweaked one way or another. There is something about the way the weak video looks that makes me wonder about phase. Is there anything obvious that I should reset to begin with? Since my objective now is just to play through the tapes for capture should I set some options for my new purposes? I had a hard time Googling some of these options so let's make them easy to find here: (ALL MENUS COPIED FOR COMPLETENESS- spacing retained - some are more obvious than others) SETUP-MENU NO.1001 01 SYNC 02 STILL TIME SELECT 03 TAPE PROTECTION 04 READY OFF MODE SELECT 05 DIRECT SEARCH 06 SHORT FF 07 AUTO REW ------------------- SETUP-MENU NO.2001 01 IMAGE MODE SELECT 02 VIDEO MODE 04 PB/EE SELECT 05 WIDE MODE SELECT 07 HSW BLANKING SELECT 08 V BLANKING SELECT 10 DOC SELECT SETUP-MENU NO.2011 11 FREEZE AT READY OFF 12 FREEZE AT STOP 13 Y-DNR LEVEL SELECT 14 C-DNR LEVEL SELECT 15 TBC REMOTE ------------------- SETUP-MENU NO.3001 01 DOLBY NR 06 AUDIO CH2 ------------------- SETUP-MENU NO.4001 01 CHARACTER BACKGROUND 02 CHARACTER H-POSITION 03 CHARACTER V-POSITION 04 STATUS SUPER ------------------ SETUP-MENU NO.5001 01 EJECT/STOP FNCTN REM. 02 9P DEVICE TYPE SELECT 03 9P FF/REW MODE SELECT ------------------ SETUP-MENU NO.6001 01 DROP/NON-DROP FRAME 02 AUTO PREROLL ENTRY 03 PREROLL TIME 04 PLAY DELAY 05 FRAME SERVO ------------------ SETUP-MENU NO.7008 08 TC OUT SIGNAL REGEN 13 9p VITC TO DUMMY LTC 14 9P INTERPOLATED VITC END TBC CONTROL 1.VIDEO LEVEL 2.SET UP 3.CHROMA LEVEL 4.HUE 5.YC DELAY 6.SYSTEM H PHASE 7.SYSTEM SC PHASE FINE 8.SYSTEM SC PHASE COARSE various deeper setup screens for the above -3 0 +3 etc. -- I am aware that there may be nothing more than hardware issues involved here. If there are obvious diagnostics feel free to share them. |
You shouldn't have to set anything to get video to display. Like the AG-1980, the AG-DS line suffers from capacitor problems.
http://www.digitalfaq.com/forum/news...empts-buy.html http://www.digitalfaq.com/forum/vcr-...-ag-ds840.html http://www.digitalfaq.com/forum/vcr-...html#post32030 http://www.digitalfaq.com/forum/mark...html#post19942 |
Once I changed the capacitors I got a perfect picture. Bear in mind that most options only have an effect with TBC enabled - thinks like head switch masking, DNR etc. |
had the same issue - its those damn electrolytic capacitors!
I bought a Panasonic AG-8700 - a nice PAL model with TBC, and has the exact same problem. Got it for less than $70 because of this problem so I'm not complaining :-) First I downloaded a free service manual, it also had a user manual in it so all functions and menus where explained. I tried to follow the diagram and diagnose the issue with an oscilloscope, but found out that many capacitors where defective. replacing a capacitor got me one step further on the path of the signal but then the next step was bad as well. I had to change ALL the capacitors on the Video boards. It took about two days of work but it was worth it. it was easier than trying to diagnose - So maybe half the capacitors I changes where actually OK... but it was just easier to take the board, remove 10 capacitors, install new ones and continue to the next 10. I replaced 100-200 capacitors. lost count somewhere after 50 :-) The Audio boards and the servo boards are OK - they use a different kind of capacitors. the boards I had to fix where two Y/C boards and two TBC boards. Good luck... |
