-   -   Damage at top corner of VHS footage? (https://www.digitalfaq.com/forum/video-capture/10553-damage-top-corner.html)
PeterVR 04-20-2020 07:14 AM
1 Attachment(s)
Hi everyone,
although I suspect that I have already seen my problem at a forum like this, I do have several vhs tapes with this problem: Damage on the top and corner of the video tape image. Does anyone know if this is due to the aging of the vhs tape or can it be solved?
An example: https://youtu.be/5Q7vOq4-T5A
Thank you in advance!
lordsmurf 04-20-2020 07:48 AM
That's "tearing" (technical term).
Simple to fix, using the ES10/15 for passthrough.
The error has nothing to do with aging. It was simply misrecorded when the tape was made. The top of the signal is skewed, and the VCR cannot lock onto the image properly.
Very common issue.
msgohan 04-20-2020 09:43 AM
2 Attachment(s)
No details were provided on the workflow used to capture this clip. In a previous post you mentioned using a Philips VR1000 into a Kramer TBC. The fix may be as simple as disabling the line TBC of the VCR, or removing the Kramer from the workflow. http://www.digitalfaq.com/forum/vide...sed-input.html
Connect the VR1000 directly to a TV, with line TBC disabled. Odds are, there will be no tearing. Turn on line TBC. If tearing appears, there is your cause.
If 1 tape blame tape, if all tapes then VCR tension:
https://books.google.ca/books?id=BHf...%20vhs&f=false (and see attached troubleshooting steps)
It definitely isn't due to the VCR being unable to "lock on". The flagging is caused by mis-interpretation of the video signal being output. This can happen at:
  • the VCR's own internal video decoder (TBC/NR circuit)
  • a CRT's AFC circuit, mentioned in that book. Sony consumer CRT service menus offer a couple different options for AFC timing, and some professional video monitors offer multiple options: https://www.youtube.com/watch?v=HEXL...youtu.be&t=157 *
  • video decoder in external TBC, capture card, flat panel display
* More in this series of videos: http://www.digitalfaq.com/forum/vide...s-showing.html
http://www.digitalfaq.com/forum/vide...g-devices.html
Attachment 11676
The Analog Devices PDF only notes head-switching as the cause of flagging, while the repair book says wrong playback tension can cause it.
