-   -   Capturing VHS on a budget? (PAL+NTSC) (https://www.digitalfaq.com/forum/video-capture/11047-capturing-vhs-budget.html)
lordsmurf 10-04-2020 01:19 PM
Originally Posted by Hemroid
Ive found a good Panosonic NV-HS950 on Gumtree in the UK for £140, do you think that will be good enough for me?
For the PAL tapes, perhaps.
But condition of a deck matters -- and NEVER trust a random non-video person's idea of "working" or "tested".
Hemroid 10-04-2020 01:24 PM
I hear ya but £320 + is a big jump
https://www.gumtree.com/p/video-reco...50b/1385477290
lordsmurf 10-04-2020 01:45 PM
Originally Posted by Eric-Jan (Post 71864)
The "Image" are the specs of a chip/IC that is used, a manufactor can decide not to use some features, to make the product cheap.
You need the specs and features of the (complete) capture device, ....and even then
Nice catch. Very true. :salute:
The SoundBlaster video capture cards + LSI Logic still irritates me. So much potential, such a horrible use of the chipset. It's so bad that it's an unusable card.
There are also a few orphaned ATI AIW cards, where the drivers are so pathetic, or the graphics RAM is so puny (16mb), or both, that the cards just is not feasible.
Chipsets can make a card, but a bad card can unmake the chipset. :old:
For a quality Panasonic S-VHS deck, £320 ($415) is not really expensive.
Hemroid 10-04-2020 02:10 PM
Yeah I understand, still I’m a gambling man.
Do you think an ATI 600 USB will be the best option for me considering I’m running Windows 10 OS? I’ve read a lot about problems due to W10.
lordsmurf 10-04-2020 02:21 PM
The 600 "clones" work better in 8/10, due to different drivers. There's also some specific chip Pinnacle cards that work well in 10 (and one in particular for PAL, a cards I often use myself for PAL).
Hemroid 10-04-2020 02:30 PM
Do you have a link to any? Minefield when you haven’t got a clue
ATI 600 clone seems best, what do i search for?
Eric-Jan 10-04-2020 05:34 PM
That's where "legacy" kicks in .... i don't think they're made anymore so look at marketplaces like eBay and Amazon, i guess Aliexpress has also the clones.
But be careful..... for the known "trapdoors" of these sites, it's up to you now.
Hemroid 10-05-2020 02:51 AM
What do mean by “Legacy” thanks
Eric-Jan 10-09-2020 11:16 AM
It's where different versions of interfaces are working without problems or even being available at all,
it's where you must pay some extra attention if this will work flawlessly
like USB3, USB2, or different versions of Thunderbold on MAC USB-C is not the same Thunderbold 3 although the connection looks the same, sometimes they are compatible, but only when mentioned, so that's also something you can't do on a budget, if you have one or the other.... some times a cheap usb dongle will do better on a beefy system, visa versa not :)
Legacy devices will do better on Windows 7/8, Windows 10 will mostly only support new products/capture devices.
Better solutions will cost you more money, Windows 7/8 good recorder & TBC & legacy capture device, or VCR with component video output & semi pro capture device with Windows 10/MAC (2013-2015 make)(PCI/Thunderbolt2)
