03-26-2021, 12:10 AM
fprefect fprefect is offline
I am about to pay a visit to someone who sells the VCR in question, however I need some advice on what to look for
For example from the attached pictures I don't see a TBC switch or indication, unlike on the NV-FS200. Maybe I misunderstood that the NV-FS88 and NV-FS200 are almost identical or the TBC is what makes them "almost identical"
Any clues will be much appreciated.
Regards,
FP
03-26-2021, 12:51 AM
FS88 has no TBC. I consider that unit worthless.
non-TBC Panasonic are not really that good, unlike non-TBC JVCs.
The following users thank lordsmurf for this useful post: fprefect (03-26-2021)
03-26-2021, 04:27 AM
Sounds like this extends over the FS100 as well?
03-26-2021, 06:33 AM
The FS88 is the same as the FS200 just without the TBC (see e.g the service manual for it.). The FS100 is a bit older.
I wouldn't say a non-TBC unit is worthless, you just need to use something external for the line-TBC function instead. Since it shares almost everything with the FS200 it could be used for replacement parts for it too.
03-26-2021, 06:42 AM
Like chaining my two ES10s after it, one in line TBC mode and the other in frame mode? Or is this a complete herecy? I think my lack of any video related background is obvious
03-26-2021, 06:54 AM
Bogilein Bogilein is offline
Yes, the two machines are identical. the fs-88 is missing the tbc unit. Use one of the recommended dvd recorders in passthrough mode and be happy.
The following users thank Bogilein for this useful post: fprefect (03-26-2021)
03-26-2021, 06:57 AM
Not much point in chaining two of them, the second one won't do anything useful, you can't adjust the TBC on them, it's always active. Using it with one ES10 is a decent option though (just be vary of the brightness clipping issues with the ES10 and other PAL Panasonic DVRs).
The following users thank hodgey for this useful post: fprefect (03-26-2021)
Sapphire Wonder TV PCI Ver. 2.2 capture card worth buying? ofesad Capture, Record, Transfer 2 06-17-2020 08:53 AM
JVC HR-D970U is worth buying for $30? Apache2223 General Discussion 3 12-30-2019 10:04 AM
Is the Panasonic AG-1980 or AG-5710 still worth it? waloshin Capture, Record, Transfer 21 07-28-2016 08:45 PM
Panasonic NV-HS800A VCR worth buying? pickle Restore, Filter, Improve Quality 4 04-04-2015 09:24 AM
Power surge protectors - worth buying? manthing Videography: Cameras, TVs and Players 2 03-07-2011 10:15 AM
Thread Tools Search this Thread
Search this Thread:
Advanced Search
