Canopus ADVC-100 giving weird colors?
1 Attachment(s)
Hi,
I came across a Canopus advc-100 device that has some color issues. At first it only happened occasionally and restarting the device several times would fix it, but now it happens very frequently. I have attached a short sample while the colors are changing, once the colors go bad, they remain like this for a while and just occasionally come back to normal for few seconds.:depressed: Tried with several different S-VHS VCRs, issue still happens. Also it's worth noting the issue only happens if the tape is a VHS tape. if it an S-VHS tape, the issue goes away. Any ideas on what might be causing the issue? Thanks in advance for any help |
Just for for future readers, I asked the same question here somewhere else and got an answer.
The problem in my case was because the VHS tape I tried had macrovision. The trick to make advc-100 bypass copy-protection is explained here: https://forums.afterdawn.com/threads...dvc100.290888/ |
