Horizontal line artifacts every 3rd frame?
5 Attachment(s)
I'm working on a project to digitize my family's collection of random tapes full of giant quantities of TV, but peppered with little bits of my siblings and I goofing around with the camcorder. Here's my setup:
JVC HR-J692U consumer VCR --> Datavideo TBC-1000 --> ATI TV Wonder 600 USB --> Win7 PC w/VirtualDub 1.9.11 & ATI drivers from this forum. I got the TV Wonder and VirtualDub based on recommendations in this forum and they are new to me. I'm seeing some artifacts in the captured video (see the attachments). It kinds looks like interlacing to my untrained eye, but it's only showing up on every third frame. The images badframe1-720x640.png and badframe2-720x640.png have the artifact, the goodframe-720x640.png image doesn't. Also, hanging off the TBC, I have a Canopus AVDC110 feeding into an old MacBook running an old version of iMovie. I'm not seeing these artifacts in parallel captures taken at exactly the same time with that equipment, nor I am I seeing them on the TV I have hooked up. badframe1-canopus.png and badframe2-canopus.png correspond to the two badframe images from the TV Wonder. That makes me think this is a problem with the TV Wonder or VirtualDub. What is this kind of artifact called? What exactly is going on? Are there any settings I can tweak to fix this? ---- Also, on a completely unrelated note, what resolution should I use to capture TV-recorded VHS? On some threads I see strong recommendations to use 720x480, but my impression that's done with an eye towards creating DVDs, because that's a valid DVD resolution. If I'm not planning on making DVDs or Blurays from any of this video, is there any reason I should not capture at 640x480 (which seems to be double the actual VHS resolution, if I'm reading Wikipedia correctly)? |
Analog video is sampled by the capture card at 720x480 that includes some overscan around the frame as safe margins, The actual video resolution is 704x480 non square pixel after removing the black pillars on the sides, You can resize 704 to 640 for square pixel but there is no need for it anymore, There is no native monitors and/or computers that are limited to this resolution, Computers and TV's can display any resolution nowadays, not only that but 640 may not be compatible with some video codecs.
If you are not capturing at 720x480 the artifact could be related to this. |
All the captures I posted are at 720x480. That's certainly true of the TV wonder captures where I'm seeing the artifacts.
However it looks like VLC stretched the Canopus captures to 720x540 when it created the png (probably to get the aspect ratio right). Looking at the codec metadata in VLC shows that capture is natively 720x480, however. That's not super relevant since that's not the capture I'm having an issue with, just a comparison. |
It could be 3:2 pulldown, or some kind of artifact from the digital processing at the TV station. You're capturing at 29.97 frames per second, right? (If NTSC.)
720 vs. 640 pixels across probably doesn't matter for standard VHS if you don't intend to make a DVD. I notice some squiggles in the screencaps that would be fixed by a VCR with built in TBC. |
1 Attachment(s)
Could this be a "comb artifact"? Oddly enough, when researching the 704x480 capture resolution suggested by a poster here, I found this: http://www.digitalfaq.com/guides/vid...d-sources.htm: Quote:
So are these "comb artifacts"? Are there any capture settings I can use to make this better, or is it just a fact of life? Quote:
That table only has "suggested capture sizes" of 704x480 and 720x480 for higher quality sources than I have (regular VHS recorded on consumer grade equipment, not SVHS or digital). So is 640x480 a weird middle resolution for VHS? It seems like I should capture at 352x480 OR 702x480? 702x480 has some appeal because it seems like its an integer multiple of the native VHS resolution on both axes, while 352x480 only doubles one. Quote:
@vhsnewb
Think of a perfect vertical straight white line. Without the line-tbc the line will be crooked (a lot or slightly that is tape dependant) , with a line-tbc it'll be almost straight (and i guess with $$$ tbc it can be perfect). Full frame tbc is another beast generally for very difficult tapes |
Think of a perfect vertical straight white line. Without the line-tbc the line will be crooked (a lot or slightly that is tape dependant) , with a line-tbc it'll be almost straight (and i guess with $$$ tbc it can be perfect). Quote:
Maybe I'll hunt one down later, especially if I decide to re-digitize our home movie tapes (my Mom had already done that with the Canopus years ago). My current project is almost more of an exploratory survey: I want to get the best quality out of the equipment I have, but the tapes I'm working on aren't valuable enough to reach for the absolute best quality. Some of these tapes have also already gunked up one VCR into uselessness, and I'm hesitant to get something nice if it'll just get wrecked. |
We use 480 lines for digital because analog NTSC has a nominal 486 scan lines of video, and the "lost" 6 rarely if ever have useful image content.
Horizontal resolution is based on the number of black and white vertical lines that can just be resolved in a distance equal to the image height, i.e., the point where they blent into uniform gray. Given that traditional SD is a 4x3 image, 240 lines resolution amounts to 320 lines in the picture width. Resolution is based on a B&W image. Judging this on a typical color TV screen/monitor can be difficult, although the concept applies to the complete system, display included. If the dot pitch is not fine enough. Color resolution of SD NTSC is much less. A rough approximation is you get about 80 lines of horizontal resolution for every 1 mHz of signal bandwidth. Thus the 3 mHz of VHS luma bandwidth nets about 240 lines of resolution. As a point of reference broadcawst industry Betacam SP tapes have about 4 mHz of luma bandwidth and 1.5 mHz of chroma bandwidth. They they could provide ~320 B&W, and ~120 lines of color resolution measured 3 to 4 dB down. However, VHS & SVHS tape formats (and the 8mm variants) have much lower bandwidth allocated to chroma (less than 500 kHz, so color resolution is on the order of 40 lines at best. Keep in mind that the bandwidth figures are based on frequency and amplitude response. Analog copies degrade according to the frequency response of the systems and noise contribution of each step. A signal that is 10 dB down on the original may be 20 dB down on the copy assuming similar response systems. That is why the quality of VHS & Video8 copies degrade so quickly with successive generations compared to the broadcast formats. FWIW: The color bandwidth limitation also acts as a low-pass filter and can cause colors to shift and smear with successive copies. 320 pixels is in theory adequate for a VHS luma signal. However, it is not adequate to capture broadcast signal luma which is more like 440 lines per picture width, or SVHS/Hi8 at ~530 lines per picture width, DV at ~660 lines per picture width, or high quality live camera analog output. |
If you have a wobbly tape, the straightening effect will be immediately obvious when you pass-through the video signal. Use S-video if you can. |
