| Patrick_S |
04-09-2022 10:24 AM |
Adjusting images with green AVT-8710 while capturing?
Currently I'm capturing some of my old VHS tapes, while using the green AVT-8710 as TBC. Sometimes the footage I'm capturing is either underexposed or overexposed, while I can adjust settings like brightness or contrast to fix the footage with this TBC, I'm not sure whether this is the right way to go. If I adjust these settings while capturing, I'll have to re-capture the same footage (now using the correct settings). This feels illogical, shouldn't it be better to just keep it at one setting while capturing and fix these image problems when I'm restoring the footage later? What would you suggest?
