Is ATI AIW Rage 128 Pro a bad choice?
I was reading through several articles on the best composite/tuner/s-video capture cards, and I picked what it says on the tin. I've been hearing conflicting reviews about its capability, though.
The unit is complete in box, with all accessories/driver discs. I also have a dedicated XP machine with an AGP slot. Should I try to cancel the order and get a different AGP AIW card instead? I'm using this card for 3/4" U-Matic, VHS, and 8mm tape digitization. Thanks! |
I should also mention that the biggest issues I'm looking to solve are audio drift-desync.
What is the full workflow?
You need actual TBC, not ES10/15 or TBC(ish). If 128 Pro, must have 32mb graphics RAM minimum. There are better ATI AIW, but it's not completely unusable. Just some quirks, and it may fight you at times. |
Which card would you say is the best for such capturing? I do not consider myself having a capture setup at all. It's a mono-only 1986 camcorder, and I have a newer Panasonic Dynamorphous, and a few other ones, paired to an EZ-cap-esque clone.
I'd like to start with fixing the audio, then get the best capture card that's friendly to capturing these formats. Thanks |
OK, the RAGE 128 PRO I bought has exactly 32 mb of RAM, but if there's a better card that I won't have to fight with or put up with issues while a better one is around is preferable. I've got a 2-grand tax return, and hundreds of unique tapes to rip. I'd very much like to make sure that I can at least try to get the most effective equipment, starting with the card itself.
