Building an AIW AGP capture machine?
I've been piecing a machine together and think I may be missing something.
I have the following so far. ASRock P4V88 Pentium 4 2.8ghz Processor 4GB RAM AIW 2006 Edition 256mb AGP capture card (NOS so all cables are included) 1200W ATX power supply Cheap ATX case that everything fits in. So my question is am I missing anything else. I haven't had the pleasure of dealing with any pre i-series builds so not sure if I'm missing something super basic. I'm pretty sure I need a gpu of some kind for video output but not sure if the AIW can handle that for me or not. |
The All-in-Wonder is indeed a capable GPU. That was the whole idea: graphics + capture card all-in-one (...der).
You didn't list storage. It's recommended to have separate OS and capture drives. |
soundcard is missing too
Are you doing Win XP or 7? Some suggestions: Power supply - EVGA 500W (way more than you'll use) 80+ Gold w/ active PFC https://www.newegg.com/evga-500-gd-1...82E16817438158 Windows OS drive - Samsung 870 Evo 500GB SSD (format in NTFS) https://www.newegg.com/samsung-500gb...82E16820147792 Initial capture drive - Samsung 870 Evo 2TB SSD (format in exFAT) https://www.newegg.com/samsung-2tb-8...82E16820147794 Archive drive(s) - preferably a NAS, enterprise, etc, SATA drive 4TB+ (format in exFAT) whichever brand you prefer and whichever capacity you need, can get 2 and keep a mirrored backup if so desired WD Gold or Black or Red, Seagate Ironwolf Pro, WD Blue if you're being cheap, take the time to let a full write-read test run before putting hard drives into use when possible If you're used to doing M.2 builds just remember you need to get the SATA cables too |
I was thinking XP since that is the lordsmurf recommended OS for using the AIW cards. And thanks for the detailed list of things to look at. |
Ah alright so you have a pretty good handle on it overall. Some of the P4 chips could cook themselves if poor cooling was used, but I think the 2.8GHz chips were fine. Still if you can get a good aftermarket cooler for it with MX-4, I'd recommend that, as the OEM ones back then were trash. Just for peace of mind and/or insurance. Personally I'd run Memtest on the sticks for a day or two and then after XP is all installed and configured and drivers are in, Prime95 for a day or two. Then you know you're good to go. No other reason for the PSU change if that's definitely a quality one. And you've got storage sorted. If you've never done the legacy installs just pop into the BIOS and make sure everything is configured properly, there might be SATA/IDE settings to change, AHCI, onboard/AGP default graphics, etc. The XP SSD will need to be MBR and you could do partition 1 for the OS @ 80GB (or whatever you're comfortable with, it can be way less) as NTFS and partition 2 the remainder so you can have the larger non-OS partition as exFAT. I like to do it with diskpart /clean and start fresh with re-initializing the disk as MBR and manually setting it up from there in the command prompt so it's already prepped when you get to it in the XP installer. Depending on your WinXP source, not sure if SP3 had exFAT support so you may need to download the update for it. If you have a pre-SP3 source I'd highly recommend slipstreaming SP3 into it before installation.
