-   -   Tons of inserted frames? (https://www.digitalfaq.com/forum/video-capture/12916-tons-inserted-frames.html)
licehead 08-09-2022 10:39 AM
Set my capture setup to a new (old) pc.
Here's my chain: JVC HR-S7900 -> Cypress AVT-8120 -> ATI 600 USB clone -> VirtualDub w/ Huffyuv
My timing settings are:
[X] Drop frames...
[X] Insert null frames...
[X] Sync audio to video...
[X] Correct video timing for fewer frames...
[X] Automatically disable resync...
[X] Austomatic
So far these are the only settings I can get that keep audio in sync with video. Getting very few dropped frames but constant inserted frames. Looking at the footage after capture I can't necessarily tell that anything is off, maybe I just don't know what to look for with inserted frames. Any help appreciated
KhAoS182 08-11-2022 07:59 AM
1 Attachment(s)
Hello! I attached my settings for the ATI 600 USB Clone, , with that capture card you don't need to check the sync audio to video. But I would recommend you to try AmaRecTV 3.10 which is perfect for me. Cheers.
lordsmurf 08-11-2022 01:33 PM
Common reason is not having 29.97 or 25 fps set correctly on lower right of capture page with preview.
