Originally Posted by Townly
3. If I am using the TBC on the deck, do you still need an external TBC?
Yes.
- line TBC and field TBC cleans the image, intraframe timing (in-frame)
- frame TBC cleans the signal, interframe timing (frame-to-frame)
You need both.
Where did you get the AG-1980 deck?
Be wary of buying TBCs from
eBay, so many faulty units there, gamble that often loses now. The 2020s are not the 00s/10s anymore, TBC buying far riskier now, flawed and damaged models. Either that, or be prepared to spend another $500 or so to get it fixed, if it can be fixed.
s-video = separated video, Y + CrCb (PrPb)
BNC take the split signal, separates each to a wire. Just be aware most s-video<>BNC cables are crap these days, thin Chinese stuff, no shield to weak shielding, be careful with buying. Extron is not really worth the premium.
