Best VCRs for linear audio playback quality?
Before we go there - yes, I know, it’s linear audio, it has its shortcomings, it sucks by default. I get it. The goal here is to not make it any worse than we have to!
Please note - I am not concerned about picture quality, internal TBC or other fancy features, I’m not even particularly concerned about S-video or S-VHS playback. There is not a single tool for every job. But my criteria is it must have a good quality transport and top linear audio playback performance. What might be some of my options? I’ve been doing my homework. It seems that at least late models from JVC are known to have very poor quality linear audio playback, even by linear audio standards. So that pretty much strikes them from the running. Mitsubishi seems to potentially be even worse. I’m not sure about earlier models from either. Panasonic - AG-1980 has a dedicated linear output, which is always nice. Not sure how performance is but I can’t seem to find any complaints about it. Of course the AG-1980 does have its other issues, and it does seem to be a high maintenance money pit. But maybe these things can be looked past. Toshiba, Sony, other big names in the VCR world… unknown. Figured it might be helpful to gather and organize this sort of information from the digitalfaq hivemind. Any recommendations are appreciated! |
No single best. Often AG-1980P, sometimes certain JVCs.
Sometimes plain VHS players --- but neither Panasonic nor JVC. I may put certain 90s Sharp on that list. There are mid 90s Magnavox that do extremely well at audio. AG-1980P = probably the biggest money pit in all of consumer analog capture. I'm not giving specific advice here, because models matter less than condition in the 2020s. It really is a case of acquiring and testing many decks. Most probably need realignment now, which will negates casual testing. The audio can be awesome on some units, when tweaked (ie, many JVCs, too). |
To answer the OP question in a short manner, The best linear audio VCR's are the ones from the 80's that had linear stereo, The heads preamp was designed for high quality audio output, Modern VCR's did offer linear audio as a convenience way of playing back home videos tapes recorded on consumer camcorders which is mostly is going to be human voice.
Regardless of make or model, linear audio tends to be very sensitive to head misalignment leading to muffled sound. The best solution is to manually align the head to the tape played. That usually means opening up the machine to adjust the relevent head azimuth screw, which for most punters is getting too technical. Interestingly on many audio cassette players the azimuth screw is often easily accessible without opening up the cassette deck. Then there can be noise issues as consumer VCR's tend to be an electrically and magnetically noisy environment. Being a tech and an enthusiast in getting the best sound out of the most challenging consumer formats I've been able to make a number of small improvements to even quite modest consumer VCRs to extract more out of the tape's linear audio track. It's usually in four areas: 1. head azimuth adjustment aids (no need to open up the VCR for azimuth adjust), 2. sometimes better electrical shielding of head wiring, 3. better magnetic shielding of the audio head, and 4. even substituting a lower noise head preamplifier. Each improvement may only be modest but the combined effect can be significant. But good general maintenance of the VCR also plays a big part not only for sound but for picture and of course avoiding damage to tapes as they are wound or played. It's not just one thing but optimising every factor. I agree with latreche that often just playing a tape on a linear stereo equipped deck improves the clarity of the sound but I suspect this is often because the stereo head is less sensitive to audio head azimuth misalignment than is a mono head. In the early years of consumer VCR's, there was no HiFi audio, only linear audio and even in later years many camcorders recorded audio only to linear tracks. Played back without any special care they can sound dire. Played back optimally these audio tracks can sound quite good. I can upload audio examples of "done poorly" and "done well". |
1 Attachment(s)
Here's a straight transfer (no filtering/processing) of linear mono audio from a PAL LP tape (radio broadcast around 1990).
PAL tape speed is slower than NTSC, so NTSC LP would sound a little better. |
