-   -   Why is sound missing on some 8mm-Hi8 playback but not all? (https://www.digitalfaq.com/forum/video-capture/13721-sound-missing-8mm.html)
Ohank 08-23-2023 11:02 AM
I picked up a Sony CCD-TR805E to archive PAL tapes. I recorded them with a Sony tr2200 many years ago. Many of the tapes have a clear picture but absolutely no sound. Actually just one of the ten I tried has any sound at all. I cleaned the main head but no change. It's not as if there are fragments of sound or intermittent. None at all. It could well have been that I used an external mic on the one that has sound. I can't remember but I did that pretty often but not all the time. Maybe 50-50. I certainly have heard sound from the other tapes before (years ago). There is a switch saying hi-fi sound. I found that on the one tape that played sound fine if I put the switch in position 2 it made it best. Position 1 nothing and the top a scratchy weak but consistent sound. Changing this switch did nothing for the tapes I couldn't hear. I'm not that sophisticated in knowing all the ins and out of these camera's but wonder if there's more that I can do in terms of a setting on the camera or physically making an adjustment? I tried both the audio out and headphones with the same results. Thanks.
Ohank 08-23-2023 02:26 PM
2 Attachment(s)
Oops. Forgot to click "upload" on those attachments. btw, the original was a tr2200e.
timtape 08-23-2023 02:45 PM
These camcorders are well known to have failed capacitors, often many. This may be the problem. Replacing the caps is difficult and specialist work unfortunately.
latreche34 08-23-2023 03:27 PM
Could the original camcorder had the digital PCM audio capability? Not a lot of consumer camcorders did have PCM but maybe worth checking the manual.
Ohank 08-23-2023 04:41 PM
Thanks for the reply. The manual for the original (2200e) only mentions pcm briefly. It says ...
"When bars (– –:––:––) appear
An index signal is marked, the RC time code is
written, or PCM after recording is made on the
tape>"
I don't find pcm mentioned (online search) for the one I have now. TR805e.
Ohank 08-23-2023 04:42 PM
If there were bad caps would it play some tapes fine and not others? Thanks
latreche34 08-24-2023 02:30 AM
No, If the camcorder is bad it will affect all tapes.
Ohank 08-24-2023 03:23 PM
Don't know if this sheds light but the one tape whose sound played OK with the TR805 had these characteristics in the capture.
Initial Audio Stream
Format: mp2
Bitrate: 192 kbps
Rate: 48000 Hz
Channels: 2
Selected codec: mp2
Audio Streams
Track 0
Format: mp2
Bitrate: 192 kbps
Rate: 48000 Hz
Channels: 2
Selected codec: mp2
latreche34 08-24-2023 04:10 PM
Those are the captured file parameters, The parameter you capture software set to capture at, it has nothing to do with what is on the tape.
Ohank 08-24-2023 07:24 PM
Aha. I hoped it would give a hint. Thanks
