-   -   Rolling image on AIW 2006 (https://www.digitalfaq.com/forum/video-capture/14331-rolling-image-aiw.html)
Feedbucket 04-27-2024 07:45 PM
1 Attachment(s)
Was doing some test capturing earlier today using my AIW 2006 on XP and left VirtualDub in Capture mode as I stepped away for an hour or two. Came back, swapped some wires, and now I can only get this (see attached). Is this a hardware failure? My VE PCI still seems work OK and the source works fine when connected directly to a screen.
KhAoS182 04-28-2024 04:50 AM
The S-Video cable is incorrectly connected or "dancing" in the connector.
Feedbucket 07-03-2024 08:10 AM
Yeah, I'd seen similar before and feared it was some kind of connection issue, something specific to the S-Video input, since the connections were all solid otherwise and all of the other I/O (RCAs in, VGA out) were still working. Turns out it was an issue with the card - I sourced a replacement and it works fine now. Fortunate since the cards are a lot easier to replace than the breakout connectors are.
