-   -   Hybrid works on Windows 7 32-bit? (https://www.digitalfaq.com/forum/video-capture/14371-hybrid-works-windows.html)
badonica 05-15-2024 12:10 PM
Which version of Hybrid works with Win7 32 bit?
Cheers
lordsmurf 05-17-2024 04:47 AM
Why using x86 version of Win7, and not x64?
badonica 05-17-2024 05:35 AM
Windows 7 32 bit
Thanks for the reply
It was the only version of Windows 7 I have on disc
badonica 05-17-2024 08:08 AM
Win 7 64 bit
1 Attachment(s)
Attachment 17935
Installed Win 7 / 64 bit,
Installed Hybrid - tried to run it then got error message
The procedure entry point “CreateDXGIFactory2” could not be located
in the dynamic link library dxgi.dll
Any ideas?
Cheers
BarryTheCrab 05-17-2024 09:08 AM
The last Hybrid that works in 7 is 2020.12.13.1
badonica 05-17-2024 10:51 AM
Hybrid
Hi,
Thanks for the info 👍🍀
