ATI 600 USB hack not in registry?
Scoured the forum for instructions on how to lower the volume on the ATI TV Wonder USB "hack". I am looking at this because I purchased an ATI USB 2.0 from LS.
Found the following from this thread: https://www.digitalfaq.com/forum/vid...#ixzz8unaIzx2d -=-=-=- Start menu -> Run -> Type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}. There are a bunch of keys under Class with similar-looking strings of characters. The first block of the one that you want ends in "C". To double-check you're at the right spot, click on this key (it looks like a folder) and you should see the (Default) value as Sound, video and game controllers in the right-hand pane. Under this key are a bunch of numbered subkeys. Expand any that have their own subkeys. You're looking for one that contains settings\OEMSettings. Hopefully you only have one of these entries, as narrowing down individual device installations is a bit more complicated. Having located the correct device and navigated to OEMSettings, right-click on the right-hand pane and choose New -> DWORD (32-bit) Value. Name it AC97VolumeLN. -=-=-=- I've found the entry. When I click on the entry, the (Default) value is Disk Drives. In that entry are a number of sub-folders (I know that isn't the proper name, but I'm going to use it): 0000, 0001, 0002, etc. There is a "Properties" folder, but no "Settings" folder. Any suggestions? |
ATI 600 is not ATI AIW. 600 has the needed hack. You have AIW. ;)
Thank God!
