-   -   Does MiniHDV have same issues with LP as MiniDV? (https://www.digitalfaq.com/forum/video-capture/14992-minihdv-issues-lp.html)
RolledJoel 03-07-2025 01:23 PM
Title says it all really. I am referring to them being difficult to playback with camcorders other than the original.
Thank you
timtape 03-07-2025 02:34 PM
Yes, even using the camera it was recorded on. The owner's manuals stated it.
aramkolt 03-07-2025 04:10 PM
The one HDV machine I've seen with a description that might indicate some sort of correction that other players can't do would be the BR-HD50U:
http://pro.jvc.com/prof/attributes/t...&feature_id=02
The auto correction feature they describe as follows:
JVC has developed an auto error correction system that operates on a frame-by-frame basis to ensure accurate error compensation during playback. After optimally calibrating the playback RF waveform with a pre-filter circuit, the VCO (voltage control oscillator) control voltage is changed so that the data reading clock phase is shifted to the position where the error rate is lowest. The result is accurate, consistent suppression of block noise and reliable, professional-standard performance at all times
I have access to a variety of pro players, so if you have a tape that you can send me that doesn't play in anything you've tried, I can try it in what I've got and let you know if any of it works.
RolledJoel 03-13-2025 02:24 PM
Thank you both. I will look into the BR-HD50U. I am based in the UK aramkout. Thank you for the kind offer.
