Is this VHS worth re-capture?
I captured my family vhs tapes a while ago and was gonna do some correction and came across possibly recapturing my tapes.
I used a panasonic PV-8661 that is just a regular vhs into my DVDO HD+ video processor via composite for the full frame video correction, but no scaling into my black magic intensity 4k unit via hdmi. There were no dropped frames. Some tapes where poor quality, but not sure that was due to my setup or not? In any case would it be a noticeable difference if I recaptured via a passthrough line tbc such as Panasonic DMR-ES35V or Panasonic DMR‑ES10 or a s-vhs unit like a JVC HR-S7600U or hr-7800u perhaps even a JVC SR-V10U ? Is this a worth task? Thanks in advance. |
Yes, that should be a substantial upgrade in quality.
So we got a consumer Panasonic VCR, some sort of upscaler and a black magic intensity 4k hdmi capture card that was designed for HD sources, and at most broadcast SD sources (U-Matic, Betacam, etc), not consumer SD sources like VHS and Video8
Yeah, I'd say recapturing them with an S-VHS VCR and an ATI or Pinnacle capture card at most would be a quality bump. Probably as good as your tapes would look. Yes an external frame time base corrector would help on not having to deal with dropped frames or audio sync issues, but for visible quality, what you and I can physically see. Then an S-VHS VCR and ATI or Pinnacle USB capture card with VirtualDub as the capture software should show an improvement. It might not be a big improvement, but it is an improvement at the end of the day. If you ever do make the jump, you could share some before and after samples. |
Can agree, especially if you were using something like an Elgato and it's crappy built in software.
I've done it before back in 2023 before getting a recommended workflow, and I can't look back at those captures without going "Man this looks like complete ass" |
I will edit some tongiht and upload hopefully.
Anyone think the JVC HR-S7500u is good/comparable to the HR-S7600U or just try to find a Hr-S7600u? I'll look into the pinnacle capture unit (suggestions on which unit?). And I thought running the source into the DVDoO HD+ (was expensive and used for an old HD projector) would help with the processing and full frame TBC. Thanks!!!! -- merged -- I decided to just get a panasonic hr-s7800u and here is what I've found so far. When I run it directly into the black magic intensity pro 4k via svideo it shows some drop frames. When I run it into the dvdo HD+ (outputs via hdmi with no upscaling) it doesn't but it will only output 480p and I set everything to zero as far as contrast, brightness etc. I thought it's best to capture without any changes and do all the processing in the computer. It appears to be slightly video processed after passing it through the DVDO when compared going directly to intensity, maybe over constrasty/white seemed washed out. I could drop the contrast via dvdo, but I'm not sure that is what to do. Not sure about a potentiometer on the chroma? I'm running test to see which looks better. Is there a better capture device? Not sure where to go from here. I will do some captures and upload. |
I now experiment with Pinnacle 710-USB and I found it is better for s-video input than Blackmagic (all models) - as Lord Smurf and others are mentioned in many threads. Not because of dropping frames (with good frame TBC I never noticed good Blackmagic (there are many bad cards of the same model) drops frames by itself, but there are a lot of other imperfections. For Pinnacle 710-USB you need crossbar thing and capture in virtual dub. If you want to edit files later in Adobe Premiere, capture uncompressed, Premiere does not accept HuffYUV. But I found processor usage under Windows 7 is about 3-16% max when capture uncompressed. For now I have learned and seen enough to switch from Blackmagic to Pinnacle-710. So for now I have 2 good workings systems - Panasonic NV-HS1000/Cypress CTB-531R TBC/Pinnacle-710USB and Panasonic NV-HS950/Cypress CDM-831TR TBC/multi format converter/Pinnacle-710USB. When JVC HR-S7722 from VCRshop will arrive, I believe those 3 will be my main VCRs along with 3 NV-FS1 for rewind and special needs. NV-FS1 has no built in line TBC, but has excellent drive and built quality (restored, with recapped PSU of course). And manual tracking adjustment by potentiometer. So in cases when Panasonic ES10 should be used I will use it with NV-FS1.
Thanks for your input. Which TBC would you suggest? And do you know if the pinnacle 710 is just as good or better than the io data? I got the black magic years ago for 8mm film capture with a telecine unit and the dvdo was from my old crt projector back in the day and remembered it stated it had a Full frame tbc. What do you think of using a VIDEONICS MX 1 ?
Thanks again. |
I've read threads where LordSmurf advises against the videonics MX-1.
I've also read threads where people use them successfully, but with a suggested dvd recorder in front of it I imagine (for passthrough line-TBC) You could also use a Datavideo DVK-100 or DVK-200 as a poor mans TBC along with the panasonic DMR-ES10 or DMR-ES15. All these create a poor mans TBC. The DVK/MX-1 would be used as a "weak" frame TBC, and something like a Panasonic DMR-ES10 would be used as a line TBC, before the frame TBC. These are budget workflows. I cannot guarantee you'll get good results with the MX-1. Might make your picture look weird or something. I'd love to see a side by side comparison. |
Yes, for telecine they are OK, they has HDMI or, at least, component output if older, but you capture in HD anyway. For s-video and composite inputs there was many wonders - each card from the same model shows different results (Blackmagic dealer is my friend so I had no problems to return cards what did not worked as they should). Now I decided to learn more and experiment with other cards, in this case Pinnacle 710-USB. And I found there is correct colours and less artifacts. About TBCs it is a question to Lord Smurf, however this question is answered in many threads before. I got those 2 Cypress cheap and, after recap (really poor capacitor soldering quality), they works about the same as green AVT-8710. I have black one too, it has no frame freezing or other problems commonly associated with black models, but in s-video it tends to simply hang on when poor quality signal is feed in, so no - black units should be avoided, but if you buy in ebay you can get the same black in green case (cheaters can simply swap boards and sell black unit as green). So TBC better buy here from LS, because otherwise you never know what you get so it is roulette. So you simply can pay twice.
For NTSC, 7500 is decent, but 7600, 7800, 7900 better. Quote:
And anyway, HD items always do poorly at consumer analog format (VHS, Hi8, etc) SD video. Quote:
It's a mixer. Mix with it. Or don't use it. Simple results on that one. Quote:
Funny enough, I recently had to re-case a mid-gen green unit in a black case. The green proc amp board was shot, irreparable. And the green case was cracked (which isn't that easy to do, as the plastic is rubbery). That unit wasn't used, it was abused. It's already en route to the new owner. |
The IT world has never learned "ain't broke, don't fix it". :rolleyes: :screwy: Sometimes more semiconductors are refused, "time to move on", so the OEMs (TBCs, capture cards, VCRs, whatever) have to locate replacements. Well, very often, those replacements are not at all the same, beyond a baseline. But details matter for image quality. Lots of devices have lots of chip changes, if the device is long-lived (more than the initial 6 months of release, often running for a year to a decade). |
I wonder why audio can keep standards, but video not? Yes, good audio devices cost not hundreds but thousands. I bought my 2 UA 2192 for about $4000 each when they was in production, and Lynx AES 16e for about $1500 20 years ago (used PCI version with cables for EUR 100 with cables few months ago, an it is up to specs, simply need PC with PCI slot!). They are still in production and cost about $900-1000 new. Why there are no professional video conversion gear what are up to specs? Even state archives use Pinnacle 710-USB! And ATI AIW! But they are consumer cards!
