Good component capture card for Betacam SP, VirtualDub?
Forgive me if this has been discussed, but I'm looking for recommendations for a capture card with component inputs to be used with a UVW-1800 Beta SP machine on Windows 10 or 11.
I checked around the forum and have seen some general recommendations for Aja and Matrox cards, but I've also seen some threads that mention Matrox doesn't seem to have the best codecs and doesn't play well with VirtualDub. I'm not opposed to using other capture software (I know Premiere Pro can capture with some of these cards and Matrox has their own software) but I'm very much hoping to capture lossless and relatively painlessly. If I have to use another capture software then so be it, but if anyone has recommendations for the capture hardware, that would be greatly appreciated. |
BM Intensity Shuttle is known to work well over component, just not from consumer VCRs via composite or S-Video, BrightEye 75 is a good device for component acquisition but pricy and hard to find. There are half decent devices that can get the job done over component such as some Elgato's and StarTech's, But there is a plethora of chinese knock offs and game capture boxes that you should stay away from.
I've had less than stellar success with Elgato products in the past, but the few Startech products I've used work well enough. I assume though that the Startech capture boxes are limited to h.264? I saw you mentioned knock-off cards, do you happen to know if the AJA Kona LHi has been bootleged? I see the price of a new unit is around $1200, but "used" units on eBay are around $200 even including the breakout box. That seems a bit off to me. |
The UVW-1800 does have an internal timebase corrector and should be stable enough for an immediate conversion to SDI with something like a Blackmagic Analog to SDI mini converter without an additional timebase corrector. From there, whatever you like that'll take standard definition 480i SDI input. The AJA KiPro also does have analog component input and can record in up to ProRes422HQ, and while not technically lossless, it is 10 bit instead of 8 bit and is generally considered visually lossless.
SDI is essentially digital component over a single wire (and can contain audio as a bonus) and it can also be losslessly converted to HDMI, but not all cards will capture 480i HDMI either. |
From what you've said here, it's seeming like the AJA KiPro would be a good option as well. Judging by the comparison sheet on the website, the KI Pro Rack does not only ProRes, but also has XLR audio inputs. That seems like it'll be the prime choice for me, this suggestion was a huge help! |
I use Blackmagic Intensity Pro (old one, discontinued, not the new, 4K one).
It is calibrate-able. Note that it captures using full range. You need to "compress" it into the limited one. It works best with the latest VirtualDub2. |
I will say that the KiPro can't do uncompressed captures whereas some Blackmagic products can, though they'll usually be 8 bit in those cases. Also keep in mind that both Blackmagic and AJA standalone capture products of that era tend to capture to MacOS formatted drives (HFS+), so you might need to install third party software to pull the content off of the drives if you don't have a Mac available. AJA also requires hard drive modules that can get a little pricy, but you can just take any size module and install a modern SSD - I've tried up to 2TB with no issues. Last and final thing I'll say about the AJA is that it records audio L and R as two separate mono audio tracks, so you do have to combine those later into a single stereo track either with a NLE or a FFMPEG script. |
The lack of uncompressed captures I'm alright with as well, as is the monitoring. I use both a Sony PVM and a modern LCD for monitoring, so direct connections are no issue on that front at least. Extremely good to know about the SSD and the Mac formatting, I'll have to look into that. Thank you everyone for the suggestions, I feel much more confident about making a selection now and all the information shared here has been extremely informative. |
If you can find a PCI card or a USB3 device that can capture directly from component and audio avoid SDI, It will require an additional SDI to USB adaptation, Unless you are going for a SDI recorder so you don't have to mess with a computer or your Betacam deck is equipped with a SDI digital output.
Aja, Matrox, BM and the likes of pro devices are good, there is no knock offs of them as far as I know, but the newer ones are expensive. |
Blackmagic Intensity Pro (both 2K and 4K) works fine with component, I use them for Betacam SP.
At least particular cards what has problems with s-video worked fine with component and HDMI. Do not know about Intensity Shuttle, never tried for component. But composite and s-video is another story. Some time ago I decided to switch to Pinnacle 710-USB. |
And it gives a moire when using Composite/S-Video connection. So, big NO. |
After I learned about this problem, I started googling and found out I was not alone. I even contacted their support. After exchanging several emails regarding this issue, I received the following response: Quote:
It's not like they produce them individually. More to it, it mostly depends on the firmware, not the hardware, because Composite/S-Video mode don't have such problem. |
However, you don't mention any testing of crashing blacks and whites. Have you done any? |
I do have some betacam players and random pre-recorded tapes, so I really should get around to doing a demo of what that looks like captured on the KiPro. Almost all the stuff on my youtube channel at this point is from U-Matic and captured via the KiPro, but U-Matic is just composite/S-Video at best, so component via betacam should look quite a bit better than this 1981 U-Matic recording: https://www.youtube.com/watch?v=51F4jNfKeNY |
