Computer specs for capture?
Good Evening everyone!
I am planning to help my dad with converting his VHS and Hi8 tapes from analog to digital and have been extensively reading through posts here on the forum. First, thank you all for the info you have shared. I originally thought I would buy a cheap converter but after reading through everything hear I quickly learned what a mistake that would be and this forum is a wealth of information. I am going to start with Hi8 tapes and currently have a working Canon ES75 camcorder with s-video output and have a Panasonic DMR-ES15 to use as a poor man's TBC. I still need a capture card and a dedicated computer. The capture device is unfortunately on the back burner until I raise a little more capital but I've found several inexpensive computers on Facebook locally that I'm interested in. The computer I'm looking at the moment has the following specs and I want to make sure it will work with a majority of the ATI or similar capture devices. From what I've seen on here this seems to fit the bill but I have read a lot of posts with people using Pentium 4 processors and not sure if AMD plays well with the capture devices. It's been a while since I've built anything and I recall there being some issues every once in a while with Intel and Pentium. Specs: CPU: AMD Phenom II X4 B55 (3.2 GHz quad-core, unlocked) Motherboard: ASUS M4A88TD-V EVO/USB3 GPU: NVIDIA GTX 470 1.2 GB GDDR5 RAM: 8 GB DDR3 Storage: 240 GB SSD Cooling: Stock OS: Windows 7 Pro SP1 (activated) PSU: OCZ ModXstream Pro 600w semi-modular PSU The person who listed it appears to be a retro system builder and are not asking a lot for it. Figured I would check here first before finding out this won't work Thanks! |
Welcome. :)
The 2000s was the heyday of capturing video, so that's when the best video hardware existed (S-VHS VCRs, TBCs, capture cards, ES10/15, etc). What you get now is just Chinese garbage. But the 2010s desktops/laptops made the 2000s capture cards better. A modern ideal capture system is mid-2010s dual-core (i3 best), SATA2, USB3, with capture HDD in easy-eject mount (so you can edit the capture on more modern systems). WinXP/7 best, and OS determines capture card options. Quote:
I would run away if that hot CPU only uses a stock cooler. Insanity. :mad4: Nvidia graphics cards are generally a problem with capture cards, not a benefit. Too many conflicts, from the 00s to 10s, and even now in the 20s. Onboard/iGPU tends to have the least amount of issues with capture (aside from AIW cards). How much is he charging for it? Quote:
Seriously, that X4 CPU with a stock cooler makes me entirely doubt that person's competence. |
Does 32-bit or 64-bit Windows 7 make a difference or is one preferred over the other? |
Sometimes even free is a bad price, more hassle than anything else.
Win7 x64 (64-bit) WinXP x86 (32-bit) |
I have good experience with Arctic coolers.
They are very quiet and effective. Available in US too. https://www.arctic.de/en/ |
Computer long gone. |
But it needs a simple mod. Unscrew the 2 screws holding down that tension bar/wire. Throw that bar/wire in the trash, keep screws with your other extra screws. The tension is unneeded, and potential problem (eject during writes!) I use this for myself: https://amzn.to/48QBXfB But you often have to carve out the plastic side grill with a knife, so it fits in the case. Too often, it's too wide as-is, needs some mm shaved off. Why use it? I prefer the door build quality, more secure. But 3x the price. Use either 2tb Seagate HDD, or Samsung EVO 2tb (not other brand/model SSD!) |
My Phenom 2X 4 955 still rocking this world like there is no tomorrow, working daily. Don't believe the hype. But yeah pick the adequate cooling rad (-> TDP 95W)
1 Attachment(s)
I have a simpler system - a longer SATA cable and a power cable extender. Once a year or two they need to be replaced and everything is fine. I use 4 Seagate Iron Wolf Pro 4TB HDDs. Processing on another computer with the same system :) Attachment 19940 |
