Is this crosstalk on my Panasonic DMR?
3 Attachment(s)
Hello, I've been experiencing some weird artifacts on the S-Video output of my Panasonic DMR, specifically the ES45v. Before using S-Video I was using the component out of this DMR into a component adapter. I had noticed that for a while I had left this component cable unconnected for a while, and so I was wondering if this could've been causing issues with my s-video output. I connected the component cable back into that adapter, and those artifacts are still there, but less.
I was hoping if someone could help diagnose this issue for me, or tell me exactly what it is. I can also confirm that the device connected via S-Video doesn't matter, I used several (Elgato, S-Video tp HDMI adapters, ATI 600, etc.) Attachment 20356 Attachment 20357 Additionally, I forgot to mention, when rewinding these artifacts are markedly worse. Not sure if this helps further diagnose the issue. Image below: Attachment 20359 |
Apologies for the bump, I've more or less solved this. I've read a lot online and saw a neat workaround people have used that works like magic. Squashing the video to 360x480 and then stretching it back again to 720x480. Not perfect, but removes like 90% of it.
It's basically horizontal blurring, it can be done better in software if I remember correctly, You are essentially throwing half of the horizontal resolution away.
I could play through the DMR's deck itself, but it has pretty high noise reduction that's always on. The image is significantly softer and less detailed. |
