Need sound card for capturing/restoring video - which model is best?
Hi, I'm looking for a new pci sound card that can capture good sound from diferent sources for restoration purposes and other kind of recordings or sound work (analog, digital, HD, etc.) like old vhs and audio tapes, old LP discs (33, 45, 78), old films (8mm, 16mm, 9.5mm, etc), Laserdiscs and other digital and HD sources.
So, what PCI card can you recommand ? Thanks to answer. |
Turtle Beach Riviera card $35 shipped: http://www.amazon.com/gp/product/B00...SIN=B0046TP9HA
Same card also here for $45: http://www.amazon.com/gp/product/B00...SIN=B007W7XR1S A second choice would be any Sound Blaster card above $25: List here: http://www.amazon.com/mn/search/?_en...%3Delectronics Amazon.ca (Canada) and Amazon.co.uk (UK) are good for these, too, if you're outside the USA. Easy. :) |
