-   -   Audio RCA cables that are not hard to remove? (JVC VCRs) (https://www.digitalfaq.com/forum/video-capture/5611-audio-rca-cables.html)
volksjager 12-24-2013 11:29 AM
is there any good quality rca cables that are not a PITA to remove from JVC decks?
i have tried monster, acoustic research, dynex, isimple and some others
all grip my decks very tightly and are hard to remove
i worry about damaging the decks terminals removing them
the el-cheapo thin red/white cables come off easily
lordsmurf 07-26-2014 09:34 AM
Even harder and bigger PITA than the composite inputs are the s-video inputs. :rats:
Did what I did -- buy extension cables. Leave the extentions in the JVCs, Panasonics, and whatever else you have. Then all you need to do is unplug/re-plug the cable from the extensions. That way, you never risk breaking the inputs on the deck. Because they WILL breaks, and they're expensive to repair!
This was an unanswered question or unresolved issue found during a site audit. It's hard to have an FAQ when the answers are missing, or final outcomes are unknown. At The Digital FAQ support forum, questions are never intentionally ignored, and may have been missed due to a forum glitch or human error. More details on the audit. (In some cases, threads have been edited/updated with newer information.)
