ATI USB 600 install on Windows 10 64-bit?
So I decided to upgrade to the free W10 OS, and reinstalling all my capture applications. I am trying to figure out which drivers to install.
Should I go with Vista 64-bit Install\Vista\Bin64\Setup.exe ? or Driver Update from diamondmm.com, VISTA® 32/VISTA® 64 DRIVER VER 22 (2008-08-05) ? Is the ATI Catalyst Media Center required ? It failed to install properly in Windows 10 during installation :screwy:. I don't recall ever using this app before when capturing with VirtualDub. Or anyone already managed to get theirs working in W10? Thanks, |
Try the Vista 64-bit drivers first.
No, you don't have to install CMC if you're only going to use VirtualDub. |
I set one up on Windows 10 a little over a week ago. I used the 64-bit Vista drivers from here:
http://www.diamondmm.com/tvw600usb-a...er-hd-600.html The only thing of note was that I was careful to install the drivers prior to connecting the capture stick the first time. I don't remember if it required a reboot after the driver install. (If it asked to, I would have). After that, I plugged it in and VirtualDub found it immediately. |
thx, I installed VISTA® 64 DRIVER VER 22 (2008-08-05) even though I had AMD Catalyst Control for my radeon card. It was able to recognize the latest drivers and only installed the missing files.
I got ATI 600 USB (scored a BRAND NEW Visiontek) working *GREAT* in Win10 x64!! (and used your drivers!)
Thank you!! :) |
1 Attachment(s)
For anyone trying to find these drivers. The webpage on diamond's site is gone, but the URL to download the drivers is still valid.
http://www.dmmdownload.com/downloads..._XP_VER_22.zip I'm also attaching them to this post. |
Thank you for all this. I'm getting Windows 10 this week. (Win7 isn't compatible with a lot of newer processors, i'm learning.)
