I was wondering if it was possible to capture at 16:9 with ATI MMC. There seems to be a couple shows broadcast that way, like The Sopranos and Enterprise. - Hambcastle
I actually don't think those are true 16:9, but another widescreen ratio.
Most PVR and almost all capturing software is 4:3 because it knows it'll have traditional source. And actually, your tv source is 4:3 with matted widescreen, not true widescreen. You'd have to capture AVI and then re-encode to MPEG, while cropping the image to widescreen in the encoder. Only HD is true widescreen, and for that, you'd need an HD capture card. |
