-   -   External Firewire needed for laptop (https://www.digitalfaq.com/forum/video-capture/8543-external-firewire-needed.html)
BarryTheCrab 03-09-2018 07:34 AM
I have a buddy who has a Canon XH-A1 HDV and no firewire in his lappy. I did not ask him WHY!
Is there a suitable quality way to get firewire into a laptop via a USB port?
dpalomaki 03-09-2018 08:26 AM
Not a problem that I have had to solve so these are only possibilities, not verified by me for us with an XH-A1
If the laptop has a PCMCIA slots this might work:
https://www.newegg.com/Product/Produ...6396-_-Product
There are several brands available at comparable price points. However, like IEEE1394 (aka: Firewire) ports, PCMCIA has all but disappeared from recent model laptops.
If it has "Thunderbolt" this might work
https://www.amazon.com/dp/B008RXYOKY...iglink20269-20
If only USB ports:
Simple gender-bender adapter plugs will not work for video capture. I am not aware of any FIREWIRE-to-USB adapters that will work for ingesting DV/HDV video streams from a camcorder via Firewire.
Other options include finding an old laptop to use for ingesting the video via Firewire, or perhaps using a desktop with a Firewire port/card and copy the resulting files to a USB memory stick/drive. Note that a firewire transfer file should be an exact copy of what was read off the tape (no quality loss).
BarryTheCrab 03-09-2018 10:35 AM
My past look into such things found there was no such capture/copy device, but this is the place to go for up to date definitive answers.
dpalomaki 03-09-2018 12:11 PM
A bit of further looking, there is one USB2 device that may provide HDV ingestion capability. However it is a bit of a long shot and dates back to around 2004 or so.
Pinnacle's (later owned by Avid) Liquid Edition Pro v6 included a break out box that provided both analog (YUV, RBG, Y/C, and composite) and IEEE 1394 ports. It likely requires a special driver and that Liquid Edition Pro software to be installed on the system. LE Pro v6 did support HDV.
BarryTheCrab 03-09-2018 12:44 PM
I'm gonna inform him to get an old lappy and HDVSplit. Path of least resistance.
dpalomaki 03-09-2018 01:03 PM
Just watch that the Laptop and its drive have sufficient speed/power to deal with the data rate without dropping frames.
BarryTheCrab 03-09-2018 01:14 PM
A little research before would have been helpful, though I still have an HV-30, under the correct settings and usage it still has an amazing film-like quality, but I wouldn't run out and buy one today.
