PC build with ATI All-In-Wonder X800/9200?
Hello everyone! :)
I have a Philips VCR with S-video out and I am looking forward to transferring my private collection of VHS to PC. I have bought the Elgato Video Capture device and it turned out to be a complete waste of time and money. The Elgato device captures the vhs in a very very random quality, most often it results that a 10 minute video lasts about a minute etc. Colors get distorted and whenever the capture is longer than 1 hour, the software stops responding during the video conversion... I tried it on 2 machines, even reinstalled one with a fresh Windows 7 installation - but it did not help at all. However, the playback in Elgato software always looks fine! There is no problem with colors, with audio & video sync, there are no blurs and video looks crystal clear as for the vhs ;) Whenever I press on start recording it gets a lot worse, there is lots of "no signal" and so on. I am completely dissatisfied with the Elgato and I am giving up on this idea. This time I want to do this properly! After having made some research, it seems that I should let go of the idea of using Windows 10 for this and any modern software. So I should simply go back in time :) I was looking for the ATI 600 USB devices but these are nowhere to be bought. I can see, that ATI All-In-Wonder cards are the best solution possible. I can buy either the X800 or 9200 (both AGP) - which one should I go for? Also, I do not understand how the VCR is then connected to the card - are there any adapters needed? Also, I will build a PC with Windows XP for that - can you provide me with any hints with the PC's specs? Any particular parts that are worth buying so it would work flawlessly? Any examples would be appreciated ;) |
You will need 2 hard drives, one for the operating system, and one for capture and working files. It's a good ideas to have external USB drives for storage --using your PC's working drive for storage invites disaster. Separate drives also allows you to use smaller drives for day to day work-- you don't need a 2TB hard drive for capture or working files, and huge hard drives for workspaces are a nightmare to maintain. |
2 Attachment(s)
thank you for the reply! :)
I found ATI All-In-Wonder X1800 and X800 with a cable - are these the ones? |
1 Attachment(s)
Image below is a photo of part of the accessories package for the AIW 1800XL. The input/output adapters are the 3 coiled wires with plastic dongles (the coiled purple wire is for inputs). The bundle of black connectors located just above the FM antenna is used to connect your monitor to the 1800XL's graphics output. http://www.digitalfaq.com/forum/atta...1&d=1527792623 |
1 Attachment(s)
ok :) so, the s-video and left/right audio cables go from VCR to the plastic dongle? Then, the cable goes to the ATI AIW card and it splits in Y type and connectors go to my monitor - do I understand it correctly?
If I understand it correctly, then the cable from the first photo (X1800.jpg) will be all needed by me? and in the second photo (X800.jpg, I added it later) the cable is also fine, but it has a larger variety of connectors to my monitor? Which one should I go for? :) sorry for that many questions edit: added a second photo from the X800 offer |
You need both sets of cables. One set connects your VCR and signal source to the card's input. The other set connects your monitor to the card's output. All In Winders are complete graphics devices with capture capability. You use the card's output to view your operating system on your monitor, the same way you use any other graphics display card. Use capture software (VirtualDub or AmarecTV) to view the capture process.
So I need 2 plastic dongles? black for output and a purple for input? Won't it work if I have only the purple one for input and use the VGA output of the other cable (as in the photos)?
You need the purple-wired dongle for capture, and the VGA cable for display.
The yellow wire in your x800 picture is an antenna. |
Ok, perfect :) so it seems that both of the offers include everything I need :) Is it a good idea to go for X1800 then and build a PC with it?
They are both excellent devices. The 1800 is probably more popular.
So, for that reason = never use Elgato. Not suggested. Quote:
But what's important to mention is that 2tb is a max for WinXP and non-USB drives. Quote:
But the more important thing to point out is how impossible it is to find that adapter if not included with the card. If an eBay/Amazon item does not explicitly state or show that it comes with that part, assume it does not. Many "complete" auctions are not complete. Without this piece, the card is 100% useless. Quote:
@lordsmurf
well, so I may have made the decision too fast. I have already ordered the X1800. Now is the time to build the PC ;) So, should I build a PC on PCI or find a motherboard with both AGP/PCI to make a versatile build and to buy a AGP AIW card in case the X1800 is troublesome? moreover, should I go with 3 GB of ram? since 4 GB is not going to be used on XP? DDR1 or 2 should be fine? |
Lordsmurf is the expert, but here is my two bits:
Best of luck to you! |
I can see lots of Dell Optiplex, for instance 755 in SFF case - would the X1800 fit in such a case? or should I rather look at something in mini tower? Such as Dell Optiplex 760?
An X1800 is a very large graphics card and it requires a full size case. I was able to fit in in a desktop Antec case, but it was a better fit after I moved it to a full tower PC.
Between the PSU needs, loud stock fan, heat, and others aspects, it's just not my favorite. It has to be modded with a new fan with cut power to be tolerable. And then there's still the software/driver quirk aspect. The AGP is just easier to install. Trivia: Hardware-wise, it's also the most "locked" card, as it can't even be hacked for WinVista/Win7 x86 AVI-only capture (something that's not reliable, but at least sometimes possible). This doesn't matter, and should not factor in to a decision to use this card, but it is an interesting aspect. The PCIe cards shared little with AGP/PCI, aside from the Theatre200 chips. Noting that you should only attempt WinXP for serious capture use of the card. |
I found PCs with these specs:
1st build: motherboard: Gigabyte GA-VM900M CPU: Intel C2D E4500 PSU: MODECOM FEEL-300ATX RAM: 2 GB DDR2 RAM HDD: 80 GB 2nd build: motherboard: MSI G31TM-P35 CPU: Intel C2D E3400 and also found a similar build with AMD Athlon II X2 260 I plan on installing Windows XP on the PC and to buy a hot-swap tray as @ehbowen suggested ;) Any hints on which one to choose and if these specs will suffice me? |
Finally,
I have found a HP DC5850 ATHLON X2 5000+ 2,6GHz, 4GB RAM, HDD 160 GB in a tower. Also saw a similar build with the Core2Duo instead of athlon, but I think I will go with the AMD :) Hope it will do its job ;) |
