VirtualDub 1.9.11, Huffyuv 2.1.1, Windows 10 issue
1 Attachment(s)
I downloaded and installed VirtualDub 1.911 + Filters.rar and Huffyuv.rar from your site on my Windows 10 pro 64-bit system. I followed the post that describes how to install Huffyuv in Windows 10 using a cmd window and it worked ok. I then captured a short test video and that seemed to work as well. But when I exit the capture mode and try to open the file VirtualDub crashes immediately. I attached an image of the popup that comes up after the crash. I tried this several times with the same result. Has anyone experienced this and found a solution?
