Uncompressed AVI to MPEG-2 archives?
Hi everyone,
Thanks to Lordsmurf and all other replies I finally have my set-up complete: VCR: Sony svo5800p or JVC HR-7600 TBC: Kramer FC-400 (Panasonic DMR-ES10 if tearing appears) Capture device: Pinnacle 710-USB Capture software: VirtualDub I am working on a Windows 10 laptop and I no matter what I try, I can't get the HuffYUV installed. It simply does not appear with the filters in VirtualDub. Because I have quite a lot of storage space, I'm considering capturing uncompressed. On this forum I found an (older) quote of Lordsmurf who stated: For about 5 years now, I routinely - capture lossless 4:2:2, - often encode out a 4:2:2 15mbps+ MPEG-2 archive copy, - and deinterlace a copy for CRF 15-20 H.264 to 4:2:2 I want to follow this process. I have such a large collection to capture that even archiving HuffYUV is a bit too much for me. Moreover, I do not need to restore. I want to archive it properly. My 2 questions: 1. Now that HuffYUV doesn't work, capturing uncompressed isn't wrong, right? 2. With which software should I archive to MPEG-2? Can I possibly still cut the beginning and end shorter? (e.g. if I turn off capture 10 minutes after a tape ended) From all the topics I conclude that it is best to use Hybrid for the H264 file with QTGMC deinterlacing. Thank you everyone!! |
Why can't you save interlaced 4:2:2 into h.264? For a fraction of the file size you get similar or better quality, h.264 is way more efficient than MPEG-2 and hard to notice the compression artifacts like you do for MPEG-2 for the same bitrate.
You can install both versions of HuffYUV (32-bit and 64-bit) in case you're not sure which version of VirtualDub is installed. |
Mostly script type like avisynth and the likes. Not that I'm saying they don't exist, I'm just not familiar with them, Have you tried Hybrid? MPEG-2 is very old and unefficient, It was the best option 2 decades ago.
Yes I know Hybrid. Thanks!
So when I directly after capturing encode to h.264 for archiving, there is no need to capture HufFYUV in stead of uncompressed, right? |
https://github.com/hofmand/video-codec-installers Quote:
Most freeware GUIs skip it, so you'd need to use CLI ffmpeg. Quote:
Interlace H.264 doesn't always cooperate with software or players, either, whereas MPEG always does. Again, when archiving, for cold storage for later, later compatibility matters. When even the current compatibility is iffy, then avoid. Quote:
My suggestion: capture and archive lossless, do some processing in AviSynth or Hybrid to at least mask the head switching noise, compress to h264 4:2:0 for general distribution (4:2:2 only for PC or compatible players) |
