-   Encode, Convert for discs (https://www.digitalfaq.com/forum/video-conversion/)
-   -   MPEG encoding and DVD burning questions (https://www.digitalfaq.com/forum/video-conversion/1390-mpeg-encoding-dvd.html)
Reading Bug 04-02-2009 01:21 PM
Hello all,
I’m new to the forum and hope you might provide some insight into my project. I have many DVD videos with damaged soundtracks, which I already have saved as separate audio files and am in the process of cleaning. I’ll then reinsert them with the video and burn them back out to DVD, however I don’t want to lose any video or audio quality in the process. I have the audio files saved as CD-quality WAVs (PCM, 44.1 KHz, 16-bit stereo) since this was the easiest uncompressed format in which to work with the restoration software. I’m at the testing stage of MPEG encoding and DVD burning, and am wondering if you might provide a few suggestions regarding parameters. I have a Mac Pro and am using VM Fusion to run XP.
I’m using MPEG Video Wizard for very minor video editing first, and will then lay the clean soundtrack over the dirty one. I understand MPEGs with high bitrates can run into trouble when played back on disc. Here are my MVW settings:
Video: MPEG-2, 720x480, 29.97 fps, 9800 kbps (vbr)
Audio: Linear PCM, which locks at 2 channels, 48 KHz, 1536 kbps
I have my video at 9800 VBR to maintain quality; MVW will export it as BLUE “100% Stream Copy,” so I feel I’m ok. I haven’t tried anything different so I don’t know if lowering it to, say, 9000 VBR will force a re-encode or not. As for the audio, PCM unfortunately requires a near total re-encode. While the results are great, I do hear a small difference on good speakers. I’ve tried first converting to both MP2 and AC-3, but to my ears they’re much worse than the re-encoded PCM – before I even mux them with video. I used ffmpegGUI for that and wasn’t impressed.
The burning software is Sony DVD Architect. It accepts the above video settings, but will re-encode PCM to 48 KHz, 16 bits. My files are each about thirty minutes long, I’m using a built-in Pioneer burner and Sony single layer 4.7 GB DVD+Rs made in Taiwan.
So my questions regarding MPEG encoding are...
1) Do you have any suggestions for “adjusting” the PCM audio before hand, so it will fit MVW’s locked setting and won’t re-encode? Or is there another app you like that adequately compresses to MP2 or AC-3?
I’ve since received a reply from Womble saying it might be an error for PCM to be rendered differently; they say it’s always RED (meaning “100% Re-encode”) but that the audio shouldn’t sound any different. They also said a future update should address my problem.
2) Is there any reason Mac won’t recognize the audio of a PCM MPEG? Perhaps because the source is WAV?
And my questions regarding DVD burning are...
1) Do you recommend different settings?
2) Should I be concerned about those bit/sample rates with such large MPEGs (each comes to about 1.25 GBs) under the above hardware conditions, even if I max out the capacity of each disc? What about good quality dual-layer discs like Verbatim?
3) Will the audio be ok once it's re-encoded, yet again, in Architect? Or can I somehow avoid that re-encode too?
4) Is it possible playback issues can occur at anytime, since the bitrates vary? Or can I rest my mind once each disc checks out ok?
Thanks!
RB
lordsmurf 05-12-2009 08:16 PM
I know we've had a couple of PMs since this was originally written, but I want to go ahead and reply to it in full right now, be sure you have all the information you need on the topic....
Not the best solution. Since DVD audio is 48kHz, it should be left in this format. Resampling the audio froim 48kHz to 44.1kHz and back to 48kHz is somewhat harmful to the quality.
This is a good method, assuming you're not letting Womble re-encode the video. MPEG editors are very accurate for editing, yet not having to decode/encode the subsequent video file that you save.
If this came right off a DVD, then the 9800kbps is more likely the maximum bitrate flag attached to the stream. Depending on the length of the recording, it's probably not anywhere close to that. For example, a 2-hour DVD would be more along the lines of 5000-5500kbps on a single-layer disc. To learn the real bitrate, you'd have to see the video in a bitrate viewer. The newest versions of GSpot Codec Appliance (v2.70) scans and shows the actual average bitrate of the file.
Muxing should have no affect.
Compression can distort and damage already-touchy audio, at times, yes. I've heard it too, it's not our imagination. The solution, however, often lies in simply pumping up the bitrate on the audio, such as 384kbps AC3, using a good AC3 encoder. I would not consider the freeware AC3 encoders good enough for this specific task, though they handle excellent audio perfectly fine. The AC3 encoder in TMPGEnc products, or Ulead products, for example, would do quite nicely. It really depends on what you have.
It might be worthwhile to do your editing, save the project, then highlight the entire AUDIO line, and delete it. Export the video only. When finished, use the back arrow to undo (or press CTRL+Z on keyboard) and this time delete the video. Just export the audio as PCM. This will give you both streams separately. Encode the PCM to AC3 in something better, be it the authoring software or a dedicated pro AC3 audio encoder. I use the AC3 encoder in the aforementioned TMPGEnc DVD Author, Ulead DVD Workshop 2, or Adobe Premiere Pro CS3. Does your Vegas install have AC3 as an option?
More stupid Mac vs Windows junk (thanks MS + Apple, way to help your customers!), MacOS expects an AIFF container and not a WAV one, for its PCM audio. I can do this in SoundForge.
If your PCM discs are coming out sounding and looking fine, then I really wouldn't worry much about it. Especially don't worry if this is for yourself or friends/family, and not professional distribution to thousands of unknown (and potentially picky) players.
It all depends on whether it's really being re-encoded or not. It would be fine converted to AC3 at 384k, it might still be transparent at PCM 1536k.
The worst that would happen is the player freezes or skips, confused by high bitrates. If you think it's working fine, and as mentioned above, are not distributing professionally, then I'd not be overly concerned about it.
I'm not really sure you're even coming close to bitrate spikes. If this is at least an hour long, and a single-layer disc, it won't spike that high. The video bitrate spike can also depend on the encoder, some of them simply will not go much above 8000kbps, even when instructed to do so.
Reading Bug 05-13-2009 05:47 PM
Thanks LS, that’s really great info to know. These discs are only for myself, but I want to author as standard as I can, for both present and future compatibility.
Since our PMs, I’ve experimented myself and have come to pretty much the same conclusions. To be clear, I only resampled the audio one time. I recorded straight off the source DVD (via DVD player) directly into the soundcard of my computer. A bit unorthodox, yes, but no other app converted without some form of quality loss. And again, I recorded to WAV because it was the easiest uncompressed format in which to do the restoration.
As for converting away from WAV (with Womble) I found MP2, at 384 MB/S with the 44.1 KHz sample rate maintained, to produce no degradation in quality in the final MPEG. I sat in front of excellent speakers, full blast, very testy segments of the soundtrack, and my discerning ear could find no loss. Even with a total re-encode. And the final disc shows no sign of loss either, after conversion to AC3 in Vegas.
The video is not re-encoded at any stage. I exported the final MPEGs at 8500 VBR instead of 9800, since 8500 was the rate of the originals and it seemed unnecessary to change it. I didn’t know how to ID those originals at first.
Here’s another question: If my final MPEGs are 8500 on the video, is there any sense in presetting Vegas to something higher - say 9000 - just to “bump up” the ceiling to protect against spikes? Or is Womble and Sony speaking the same language?
Thanks again :)
admin 05-13-2009 07:18 PM
I would not set it to something higher, no -- at this point, it seems you're getting good results, so I'd obey the saying "ain't broke, don't fix it".
