-   Encode, Convert for discs (https://www.digitalfaq.com/forum/video-conversion/)
-   -   MP4 AVCHD Converter Software to MPEG? for PowerPoint presentation (https://www.digitalfaq.com/forum/video-conversion/3761-mp4-avchd-converter.html)
el1ero 12-22-2011 11:16 AM
I recently bought a Sony WX9 digital cam, and have to insert the videos captured on Power Point for a presentation. What you recommend me? I need to change the format but the codifying also. Which software should I go for? Any expert? Thanks :thumb:
kpmedia 12-28-2011 06:11 AM
If this is for a one-off of some kind, you can use Avidemux (freeware) for the conversion.
Input the MP4, save as MPEG-1.
A similar question was asked and answered here a month ago: http://www.digitalfaq.com/forum/vide...-edit-dvd.html
Skip to step #3.
What does "codifying" mean, exactly? I'm not entirely clear on what that part of your question means.
Hope that helps. :)
